Author Topic: leak from dizzy..  (Read 2687 times)
Offline rowlers
  • I'm back - MK7 GTI
Re: leak from dizzy..
« Reply #10 on: 03 June 2007, 12:22 »
1990 valver..
I'm not very good wth ETKA then eh!
« Reply #11 on: 03 June 2007, 21:31 »
ok, dizzy version for a KR is #7
027 905 261 - seal for distributor 7 - 6.22+VAT :)
Offline rowlers
« Reply #12 on: 15 July 2007, 09:12 »
forgot to update...
anyhow put the new seal in and its made absolutley no difference what so ever! Still pi$$ing oil out!
any other ideas? I'll maybe try some sealer on the face - but this will stop movement!
« Reply #13 on: 15 July 2007, 10:23 »
sure its not the rocker cover? also may be worth checking the breather system isnt clogged up
Offline rowlers
« Reply #14 on: 15 July 2007, 11:41 »
there is deffo oil in the dizzy though :undecided:
I'll have a look later and confirm!
« Reply #15 on: 15 July 2007, 11:44 »
ah oil inside dizzy is a different sal that you cant buy from vw. theres a couple of posts somewhere that show you how tro replace it and what size you need
Offline rowlers
« Reply #16 on: 15 July 2007, 11:51 »
sorry - not oil inside the actual dizzy, oil comes out when you remove the dizzy from round the outside of it - the oil seal inside the dizzy must be doing its job - nothing is in the cap.
 :grin: :grin:
Offline rowlers
« Reply #17 on: 17 August 2007, 17:24 »
late update...
Had the dizzy off and there is still oil pi$$ing out. NO OIL in the cap though.
Its not the rocker either so how is this oil getting out???
I'll take some pics and show you - amy be you can come up with some ideas!!!
Offline DarnPB
  • Formerly Darnpistonbroke
« Reply #18 on: 17 August 2007, 17:45 »
You could have a small crack in the head or the leak could be coming from the stud that the dizzy is mounted to. (If that is how it is mounted) Remove the stud and see if the other end protrudes into the head itself. If it does, degrease the whole lot and refit stud with stud lock or thread sealant.
Bear in mind I do not yet know the 16V, so I could be talking out of my @rse!!!
Offline rowlers
« Reply #19 on: 17 August 2007, 17:48 »
the dizzy mounts direct to head and bolts on - no studs.
The oil is coming past the end of the camshaft and leaking through the mounting surface of the head and dizzy. The O ring should seal it but it doesn't for some reason?
