Author Topic: new connectors and stuff  (Read 767 times)
Offline rowlers
  • I'm back - MK7 GTI
« on: 26 May 2007, 12:52 »
just been out for a fiddle, :grin: :grin:
crimped new connectors onto all the temp sender wires, as the old plugs were a bit crappy.
I also tightened the gearbox earth as it was loose!!
started up , but now its idleing at about 1500, then drops to about 1200 when warmed up a bit
why is this, do I now need to set uo again?
Offline Gambit
Re: new connectors and stuff
« Reply #1 on: 26 May 2007, 13:12 »
just turn the idle screw down till its 1000rpm, the old connectors must have been dodgy
Offline rowlers
« Reply #2 on: 26 May 2007, 13:33 »
just shows eh - things are broken and you don't even know it!
I'll go out in a while for another fiddle :grin: :grin:
On a similar note, I was trying to undo the earth that is underneath the coil, so that I could fit a new one, but I can;t get at the bolt/nut whatever it is! I can't even see what size it is but it feels like 10mm?
Offline cняis
« Reply #3 on: 26 May 2007, 17:06 »
Just cleaned my sarter motor connectors up today as over the last 3 or 4 days its been cranking over VERY slowly... thought it might have been a dodgy starter motor, but i just tried cleaning the connectors on the off chance... worked a treat!!  :cool:
Offline rowlers
« Reply #4 on: 26 May 2007, 17:48 »
Just warmer her up, and adjusted (ISV unplugged airbox bunged etc..) now idleing a treat at 1000rpm.
 :wink:
