Author Topic: Odd problem!  (Read 1095 times)
Offline kittie
Odd problem!
« on: 22 May 2007, 09:30 »
So I was driving along the M62 yesterday evening, when I noticed a strange occurence - the revs would wobble, and dip (only on the gauge not in reality), come straight back up and then the coolant light would flash a few times.
I wonder if it's just something to do with the instrument cluster or some odd wiring thing, becuase as I say, the revs didn't actually drop and the coolant level is fine  :undecided:
Oh this is on my 8v digi by the way, and other than this it is running absolutely fine  :smiley:
Offline Simon8v91
Re: Odd problem!
« Reply #1 on: 22 May 2007, 13:21 »
It could be that the clocks are not properly earthed or a first sign that your clocks are on the slippery slope
Offline MK4_20VT
Re: Odd problem!
« Reply #2 on: 22 May 2007, 16:25 »
My old mk2 had this problem when I had the engine upgraded, found the cause on mine to be the earth lead that connects to the cam cover was loose, The revs dropped when I turned the lights on too  :grin:
Check your earth leads
ps. If you see a Dark Blue V-reg Mk4 GTI fully colour coded around Liverpool/Wavertree give us a wave, I'm a Formby boy but work in Wavertree  :smiley:
Jay
Offline Simon8v91
Re: Odd problem!
« Reply #3 on: 22 May 2007, 16:39 »
^agree  :smiley:
this pic from a previous post is the earth lead in question.
http://www.golfgtiforum.co.uk/index.php?topic=56669.msg437238#msg437238
Offline kittie
Re: Odd problem!
« Reply #4 on: 23 May 2007, 09:37 »
Jay
Oh I'm quite often near there to go to the big asda on smithdown road lol - look out for my red 8v!!  :grin:
Thanks for the info and pic, very helpful, I'm hoping it is a bad earth now as I really don't want to change the clocks!
It could well be though - my boyfriend fixed a broken wire thing (something to do with the idling) the other week and also I changed the plugs/leads/air filter etc the other day, so it may well have been knocked.
Will check it later  :smiley:
Re: Odd problem!
« Reply #5 on: 30 May 2007, 16:12 »
A dappy rev counter is also a sign that your hall sender in the dizzy is about to die! Best you souce a replacment dizzy just in case ;)
