Author Topic: Len's Mk3 16v ~ The Rebel Car! New Wheel Pics Page 90  (Read 610682 times)
Re: Len's Mk3 16v *Lowered Pics!- Page 16*
« Reply #420 on: 04 May 2011, 16:29 »
I believe you will struggle to get a 100 crank in and working, to use the diesel crank needed loads of work to the block to get clearance.
Also that long a stroke means you will be limited on revs.
« Last Edit: 07 December 2011, 11:00 by Wayne »
Offline Ess_Three
« Reply #421 on: 04 May 2011, 16:34 »
I believe you will struggle to get a 100 crank in and working.
Built a few 2.1's @ TSR and to use the diesel crank needed loads of work to the block to get clearance.
95.5mm will go in an ABF...it hits the oil squirters, so you need to 'clearance' them...and as long as it's fully knife edged, lightened and balalnced, it's good for 8000-8500 RPM all day...
But it brings its own problems.
Trigger wheel?
Rods? Can't use ABF.
Pistons? Can't use ABF if you are going 2.1.
Compression?
What compression?
10.5:1 is useless on big cams...
It can be done...most of the bits are in my garage ready to go...but you need to know how.
100mm stroke must be difficult...and I'm still unsure how you get to 2.3?
..but gaining motorcycles.
« Reply #422 on: 04 May 2011, 16:50 »
My maths are rusty but you would need a longer stoke than 100 I believe
Offline Len
« Reply #423 on: 04 May 2011, 16:57 »
Didnt I say bore as well? :rolleyes:
www.sas.org.uk
www.the-ace.org.uk
Offline Ess_Three
« Reply #424 on: 04 May 2011, 17:13 »
My sums were based on an 83.5mm bore...the largest you can go reliably on high compression.
Why don't YOU give us the maths then?
Offline lemski
  • 16v
« Reply #425 on: 04 May 2011, 17:50 »
Len make the 2.3 happen then tewll me cos i want one. Have my spaire block sat there
« Reply #426 on: 04 May 2011, 19:59 »
Your maths still don't add up. :rolleyes:
Offline Len
« Reply #427 on: 04 May 2011, 21:14 »
Not my maths! You think I'm doing this all by myself!
What I have been told.
And I have no intention of questioning it!
www.sas.org.uk
www.the-ace.org.uk
Offline lemski
  • 16v
« Reply #428 on: 04 May 2011, 21:18 »
How mant tbs u havin len?
Offline Len
« Reply #429 on: 04 May 2011, 21:22 »
ummmmm set! :grin:
www.sas.org.uk
www.the-ace.org.uk
