Author Topic: Len's Mk3 16v ~ The Rebel Car! New Wheel Pics Page 90  (Read 610678 times)
Offline Shady Pioneer
  • graphic designer.
Re: Len's Mk3 16v *Lowered Pics!- Page 16*
« Reply #410 on: 04 May 2011, 14:26 »
Not another 'so called' BAM conversion... :rolleyes:
Offline Len
www.sas.org.uk
www.the-ace.org.uk
Offline Len
« Reply #412 on: 04 May 2011, 14:30 »
BAM?????
www.sas.org.uk
www.the-ace.org.uk
  • graphic designer.
« Reply #413 on: 04 May 2011, 14:32 »
BAM?????
225 1.8T out of S3/TT.  :lipsrsealed:
Offline Len
« Reply #414 on: 04 May 2011, 15:41 »
Oh no! Nothing so tacky!
16v abf with tons of money thrown at it! :shocked:
Big bore/stroke to 2.3 litres
Throttle bodies, flowed and ported head with bigger valves, catcams, tube exhaust manifold. Emerald ECU, decat.
www.sas.org.uk
www.the-ace.org.uk
  • graphic designer.
« Reply #415 on: 04 May 2011, 15:45 »
Apart from the bold bits, this whole post made no sense to me.  :grin:
« Reply #416 on: 04 May 2011, 15:48 »
Sounds good but you would be better running a diesel crank and staying around 2.1 if you want it to rev.
Don't think you can even get an ABF to 2.3ltrs anyway
Offline Ess_Three
« Reply #417 on: 04 May 2011, 16:15 »
How are you getting to 2.3?
Even using 83.5mm pistons (the largest you can go reliably on an ABF block) and on a 1Y Diesel crank (95.5mm stroke) you only get 2090cc.
I believe Eurospec do a stroker crank...which may give slightly nearer 2200cc...but 2.3?
How?
Have you found a 4 branch for an ABF that's any good...if so, please let me know...because I haven't.
Supersprint make one...if you can find one.
What sized valves are you proposing?
Hard to get much bigger than standard...+1mm will go...at mega expense.
Just curious...  :smiley:
..but gaining motorcycles.
Offline Len
« Reply #418 on: 04 May 2011, 16:22 »
100mm crank.
Will have to get a tube manifold made.
www.sas.org.uk
www.the-ace.org.uk
Offline Ess_Three
« Reply #419 on: 04 May 2011, 16:23 »
100mm crank.
Wo does a 100mm crank?
Eurospec?
Doesn't a 100mm stroke crank give you 2190cc?
I thought that was the one that gives the 2.2.
« Last Edit: 04 May 2011, 16:29 by Ess_Three »
