Author Topic: post 16v brake conversion  (Read 1273 times)
Offline paultownsend
« on: 21 May 2007, 12:24 »
just carried out the 256 brake conversion for my 8v. everythibg went well and took over just 2 hours! the only problem is, the pedal feels spongy. like my old set up did before fitting the upgraded 22mm master cylinder. now iv bled the system twice (FULL BLEED), but still have the same problem.the onlt thing i can say, is that i used the pre-used disks and pads.they still have life in them, but are pretty worn,would this cause the problem? Paul
Offline sesterfield
Re: post 16v brake conversion
« Reply #1 on: 21 May 2007, 17:20 »
I recently changed the disks/pads on my 16v and after bleeding the system the pedal feels a bit spongey - I suspect I have damaged the master cylinder by pumping the pedal too far down.  Maybe a similar thing has happened to you?
Offline G60GTI16V
  • GTI Mk1, 2, 3, 4 now VRS Hell Yea!
« Reply #2 on: 21 May 2007, 17:22 »
have you got the goodridge braided hoses they stop alot of spongyness  :wink:
« Reply #3 on: 22 May 2007, 00:40 »
iv used the easy bleed kit so never touched the pedal. also i experienced no spongeyness before, so shouldnt really need to use the goodridges.paul
Offline takethefifth
« Reply #4 on: 22 May 2007, 03:17 »
Used pads shouldn't make a difference, did you clamp the rear bias valve when bleeding? I'm not sure if it effects the fronts but i know not clamping it gives problems bleeding the rears.
« Reply #5 on: 22 May 2007, 11:28 »
yes clamped it.i consider myself to be a brake bleeding expert!
« Last Edit: 22 May 2007, 12:16 by paultownsend »
« Reply #6 on: 23 May 2007, 22:09 »
as i thought.new pads and disks fixed the problem! they more worn than i originally thought.
« Reply #7 on: 24 May 2007, 01:57 »
Glad you got it sorted!  :smiley:
« Reply #8 on: 24 May 2007, 11:34 »
can really reccommend this conversion lads and ladies.took an hour tops each side to change everything over, hubs etc,
brembo disks and pagid fr pads from gsf £55
hubs and calipers from breakers £60
new bearings pressed in £40
braking is more than enough for a std 8v
gave the disks a good clean and they worked out the box
job done!
Offline j_s
« Reply #9 on: 24 May 2007, 15:01 »
Half done this already but have now fitted a 22mm master cylinder and will have mk4 calipers on the rear along with goodridge hoses all round, not felt the difference much with only the larger front discs and calipers yet but hope the other bits i'm currently doing will improve everything :smiley:
James
