Author Topic: Gearbox  (Read 3384 times)
Offline Danr
Gearbox
« on: 08 February 2004, 17:52 »
Mk1 golf cab wont select reverse, how much to fix? or would a new gearbox be the way and how much would that cost?
cheers danny
Offline gti fly bye
  • VW MK4 GT TDI, ITS A SMOKEY ALTERNATIVE!
Re:Gearbox
« Reply #1 on: 08 February 2004, 20:23 »
forst, replace your gear linkage bushes, you can get a kit on ebay!http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=2459207576&category=9889
If than it do't work, it cold be the sycromesh, i'm told this is a common problem, than its a case of repair or replace, there is one on ebay!
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=2459135301&category=9889
BEAT ANY GTI (TOWING A CARVAN, UPHILL)
golfvr6
Re:Gearbox
« Reply #2 on: 08 February 2004, 22:53 »
Reverse gear doesn't have a synchromesh.
Offline Danr
Re:Gearbox
« Reply #3 on: 08 February 2004, 23:01 »
Any1 know how much it would cost for a garage to change it?
golfvr6
Re:Gearbox
« Reply #4 on: 08 February 2004, 23:03 »
change what? the box?
Offline Danr
Re:Gearbox
« Reply #5 on: 08 February 2004, 23:04 »
yeah, the car has done 115000, would be better to just get it fixed, i dont really know the best option, some1 enlighten me pls ???
golfvr6
Re:Gearbox
« Reply #6 on: 08 February 2004, 23:07 »
A recon box will be a few hundred, a couple of hundred labour.
So i guess you could get it done for about 500 bar  :)
Offline Danr
Re:Gearbox
« Reply #7 on: 08 February 2004, 23:10 »
Bolloxs to that, wont bother buying it then unless he has it done
Offline richandhazel
Re:Gearbox
« Reply #8 on: 09 February 2004, 03:32 »
Could just be the linkage needs adjusting.
Offline modulater
Re:Gearbox
« Reply #9 on: 11 February 2004, 21:06 »
try selecting reverse under the car with a pair of mole grips on the selector shaft
