Author Topic: Gearbox  (Read 3383 times)
Offline mk1
Re:Gearbox
« Reply #10 on: 11 February 2004, 21:12 »
If you get another box, rich will buy your old one for the case ;D ;).
Bet it is the linkage, as rich the gearbox expert said ;).
Steve.
Offline richandhazel
Re:Gearbox
« Reply #11 on: 12 February 2004, 01:07 »
Yeah I'll have your old one........I'm busy collecting them as Steve has noticed ;D
Following on from what modulator said, better still, disconnect your linkages at the box........its dead easy, one wire clip and 2 plastic clips. Now move the gearbox selector lever into reverse on the gearbox itself. As you look at it I'm pretty sure (although I may be wrong and its 1am so I don't intend to go out and verify) its pull towards you and then right.........you should hear that distinctive reverse gear sound as it engages. Try it a few times..........nice and positive? Then its your linkage out of adjustment.......if not see me.......reverse gear should be a piece of p!ss to fix and I have plenty of spares.
Offline Danr
Re:Gearbox
« Reply #12 on: 14 February 2004, 12:24 »
Tanks for all the help but i becided not to buy it i wasnt payin 900 when it wasnt even workin right  ::)
