Author Topic: Fog lamps  (Read 2805 times)
Offline Brin
Fog lamps
« on: 19 February 2003, 22:30 »
Hi guys.......Ive just brought a totally mint mk 3  in dragon green which is not fitted with the factory fog lamps   Are they a big job to fit ?   also the rubber strips which run down the roof from front to back have been removed at some time to fit new screen and are very uneven been told that these are impossible to get back flat......Is that right ?
« Last Edit: 01 January 1970, 01:00 by 1055631600 »
Offline stoat
.Re: Fog lamps
« Reply #1 on: 20 February 2003, 18:16 »
Dont think they are hard to fit. I think the wiring loom is already in the car.  On the drivers side at the bottom of the front bumper behind the small mesh there is a connecter there which I think must be the wireing loom, I have this too but have not had time to work out if it is so if you fancy a go and if you could let me know that would be much appreciated
thanks
ps.  Why has the rubber been removed to fit a new screen?????
MK3 GTI 8V
Offline Brin
Re: Fog lamps
« Reply #2 on: 20 February 2003, 21:30 »
Thanks for reply not sure why trim was removed.......car has never had paint but owner said screen was replaced .......which was the only reason i could think of ......P,S Was going to buy fogs from Big Boys Toys unless you know anywhere cheaper
Offline stoat
Re: Fog lamps
« Reply #3 on: 24 February 2003, 17:06 »
it all depends if you need the wireing loom you will have to find that out first of all
MK3 GTI 8V
Offline Freddy
Re:Fog lamps
« Reply #4 on: 24 October 2003, 19:25 »
Hi, just replaced the false spot light panels with actual factory spots. Yes you need the wiring loom that has the headlights, indicators, horns and now spots on it. Plugs straight in (big socket by top of radiator). I had to swap headlight connectors though. I also changed the dash switch to a later model one that allows spots on with park or headlights.
Offline k.d.wallace
Re:Fog lamps
« Reply #5 on: 13 November 2003, 03:16 »
I got a good price for fogs from Euro car parts - about 34.00 each I think. Maybe plus VAT - I can't remember. Not sure how that compares to what you have found.
