Author Topic: Which suspension kit ?  (Read 2311 times)
Offline DanGtd
  • Mk2 Golf GTD
« on: 05 February 2004, 12:56 »
Im looking to uprate the suspension on my Mark 2 GTD 1990. I am unsure which kit is the best, have previously had a boge/ sachs kit which was good and is only ?170 (but only has a drop of 35/40 mm). would welcome any feedback on any suspension kit they have fitted.
Mk1 Golf Gti campaign in Mars Red(16 sec Quarter mile)
Mk2 Golf Gti in Tornado Red
Offline davidhawkins_78
  • Valver Bad Boy
Re:Which suspension kit ?
« Reply #1 on: 05 February 2004, 17:15 »
I must say alot of people will steer u in the way of Koni's and Eibach but they can be expensive ... plus the springs aren't matched to the shocks
I've got a damper adjustable SPAX kit - only 40mm drop but that's sensible and u'll not have trouble with exhausts bangin on axles ect if you go potty !!
The kit was just over ?300 new and take it from someone who races and has a automotive degree - other than a ride height / damper kit u can't beat it !
'89 Monza Blue Valver
to quote a VW engineer, "the Mk1 was the prototype, the Mk2, the real thing!"
Blue MK2
« Reply #2 on: 05 February 2004, 17:21 »
Coilovers are reccomended
I have Supersport goldlines on mine. they are a buget kit but the handling is the best!
ohh and the ride is quite harsh.
You can drop the car to 120mm and your looking at ?350
Offline cheech
« Reply #3 on: 05 February 2004, 17:35 »
Cheap ones from venom and raceland are good if your on a tight budget!
golfvr6
« Reply #4 on: 06 February 2004, 00:14 »
koni shocks and eibach springs are the bollox  ;)
Offline Gambit
« Reply #5 on: 06 February 2004, 09:13 »
i'm running Eibach springs & raceland shox, along with eibach arb's
the ride is firm/solid but not at all harsh and it goes round corners like its on rails
  • Valver Bad Boy
« Reply #6 on: 06 February 2004, 09:23 »
Calling all you guys with *firm* suspension etc ...
Anyone have any problems with lift off oversteer when really using the handling to the max ?
Slowly starting to push her more and more and it almost caught me out one day - just wasn't expecting it !!! Normally front wheel drive cars have to be really provoked .... might have to adjust the rear dampers you think ?
Offline Gambit
« Reply #7 on: 06 February 2004, 09:33 »
its even more apparent when you have a the eibach arb's on
thing is though with the golfs its predictable & controllable, unlike others such as 205gti's where it just snapped and 9 times outta 10 found yourself pointing in the wrong direction!!
Offline DanGtd
  • Mk2 Golf GTD
« Reply #8 on: 06 February 2004, 11:15 »
Cheers Dave,a couple of questions about the spax kit, how easy is it to change the damping, and do u have any other mods ie powerflex bushes/ anti roll bars.
  • Valver Bad Boy
« Reply #9 on: 06 February 2004, 14:07 »
I used standard VW bushes - just didn't have the cash for the powerflex stuff and standard ARB's too ...
Both front and rear shocks are adjustable on the car - the fronts are the usual key on the top of the shock, the rears have a head u adjust with a flat head screwdriver on the bottom of the shock. Nothing like other Koni's i've seen where the rears are adjustable, but they have to be removed from the car / compressed / twist to adjust crap !!!
Try these people for the kit http://www.motorsportworld.co.uk/
Cheapest anywhere by a long way - 40mm kit is Part no. TAP408
Go for it and enjoy lift off oversteer fun  ;D
