Author Topic: 8v to 16v head swap  (Read 4494 times)
Offline dubaudio1
8v to 16v head swap
« on: 04 February 2004, 22:51 »
hi
i`v got mk3 gti 8v engine code 2E.i`m thinking is it posible to change the head to 16v from mk3.if it is what else do i need to do,swap.
what are the prices for 16v engie from mk3?
thanks
Offline Golfer
Re:8v to 16v head swap
« Reply #1 on: 05 February 2004, 08:46 »
Might as well sell your 8v and buy a 16v - unless you've spent loads on mods for your 8v already ;).  16v do cost a bit more, but not much.  Certainly less than the cost of new engine and god knows what else.  I'm guessing (but I don't know) you'd need to do some stuff to the gearbox (diff ratios???) and other stuff.  Just guessing, but I can't see it would be cheap.  Also, when u come to sell her on, it might look a bit odd - was an 8v, now a 16v.  Presumably the V5 would still say 8v??????? :-\
Just a few thoughts - useful?
1998 Mk3 GTi 8v - now sold :(
2003 BMW 320d 150bhp now bought :)
2002 Seat Leon (almost a Mk4!)
Offline davidhawkins_78
  • Valver Bad Boy
« Reply #2 on: 05 February 2004, 09:00 »
The engine are bound to have differences in things like compression ratio's etc so I wouldn't even attempt it *blind* so to speak ...
With the money it would cost I'd say either mod your 8v or get an engine swap for a 16v ... safer and alot less hassle !
'89 Monza Blue Valver
to quote a VW engineer, "the Mk1 was the prototype, the Mk2, the real thing!"
Offline dubaudio1
« Reply #3 on: 05 February 2004, 20:19 »
thanks.i don`t want to sell my car,so the engine swap might be happend.does enyone know whot are the price for 16v engine and all ather bits to do the swap?the ather think is my car is LHD.will the engine from RHD fit?
Offline mk1
« Reply #4 on: 05 February 2004, 22:43 »
Don't bother with the 16v head on a 8v, lots of different parts to swap over. R/H drive engine is the same as a L/H drive one. Manifolds etc may be different and you will also need the exhaust down pipe, engine ecu, wiring harness, flywheel and clutch, coolant hoses, alternator, etc, etc.
Steve.
Offline Rodney
  • Mk3 95 3-door Gti 8v
« Reply #5 on: 09 February 2004, 15:54 »
Don't take my word for it, but I have heard that you can directly bolt on a Mk2 16v gti cylinder head onto a mk3 8v gti engine. In fact this was something I was going to consider doing myself so when I have done some more research on it I will tell you.
A second hand mk2 16v gti head only costs about ?100 - ?200 depending on its condition, and then you could have it reconditioned for little money. I don't think any parts need to be changed over.
Hope this helps and if you find out this is impossible please inform me.
Thanks.
Offline dubaudio1
« Reply #6 on: 10 February 2004, 06:13 »
thanks rodney.that`s sound good.
