Author Topic: Clutch Problem?  (Read 2121 times)
Offline haf1zur
Clutch Problem?
« on: 24 April 2007, 08:19 »
Hi
Realised after driving another mk3 that the clutch is very very high up, and also, when i put my right foot down on the gas, after about 2000rpm the rev counter increases as if the clutch is pressed in.
Wondering if that is a new clutch or just need to bleed the master cylinder?
Any help appreciated
Hafizur
Offline ROB3611
Re: Clutch Problem?
« Reply #1 on: 24 April 2007, 10:53 »
Sounds like the clutch is slipping pretty bad, new clutch time I'd say!
Offline Andy_GTI_mk3
Re: Clutch Problem?
« Reply #2 on: 24 April 2007, 11:14 »
Sounds like you need a new clutch dude!
Just had mine done two weeks ago along with the flywheel after my clutch casing shattered.
« Last Edit: 24 April 2007, 11:20 by Andy_GTI_mk3 »
Moved on to something fun and french... how I miss the german build quality!
Offline haf1zur
Re: Clutch Problem?
« Reply #3 on: 24 April 2007, 11:21 »
Would these do the job?
Cilck Here
Click Here
Or should i just get a standard one from the dealers, i have a very heavy right foot so would be nice to have it last a while. If any of you know a better source costing less then please let me know.
Hafizur
Offline Len
Re: Clutch Problem?
« Reply #4 on: 24 April 2007, 16:23 »
The second one looks fine and there is a thrust bearing!
Certainly wouldnt pay 200 quid for an OMP one!
www.sas.org.uk
www.the-ace.org.uk
Offline haf1zur
Re: Clutch Problem?
« Reply #5 on: 25 April 2007, 11:30 »
ordered the second one, 95 pounds including next day delivery, which isnt too bad
just need a diy guide on how to fit it, would the haynes manual have this info?
hafizur
Offline Len
Re: Clutch Problem?
« Reply #6 on: 25 April 2007, 12:09 »
It will but not always that detailed.
Basic guide.
with car on ground undo centre wheel nuts.
Drain gearbox.
jack up
Split bottom suspension ball joint
Remove drive shafts
Split gearbox away from engine, supporting both seperately
Change clutch
Put back together.
That is very simplistic and have missed out a lot of small steps!
www.sas.org.uk
www.the-ace.org.uk
Offline boneybradley
  • Back in a Mk3...
Re: Clutch Problem?
« Reply #7 on: 25 April 2007, 12:19 »
len you forgot about the way the clutch is bolted to the crank and then the flywheel covers this....and that the clutch is not just bolted to the flywheel like normal car's.......and the fact you need a spline key to remove the driveshaft's.
not the simpliest of job's worst luck as everything is back to front
Offline Len
Re: Clutch Problem?
« Reply #8 on: 25 April 2007, 12:37 »
  :huh:
www.sas.org.uk
www.the-ace.org.uk
Offline bored_Welsh_lad
Re: Clutch Problem?
« Reply #9 on: 25 April 2007, 13:25 »
dont you need to align the clutch also??
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
