Author Topic: shark fin aerial  (Read 2309 times)
Offline bmx
shark fin aerial
« on: 23 April 2007, 09:06 »
got one of these at the weekend.i was that impresed i thought i would share my find with you. the reception is spot on, picks up everything. i did have to swap the conector as it was fitted with the older style vw connector.
http://cgi.ebay.com/ebaymotors/VW-SHARK-RADIO-ANTENNA-BEETLE-POLO-LUPO-BORA-PASSAT-GOL_W0QQcmdZViewItemQQcategoryZ33639QQihZ006QQitemZ160104886990QQtcZphoto
Offline Creepy Coupe
Re: shark fin aerial
« Reply #1 on: 23 April 2007, 10:02 »
That's exactly what I need, was it easy to fit, I assume you had to drop the roof lining. :smiley:
Offline bmx
« Reply #2 on: 23 April 2007, 10:21 »
just the black plastic strip at the back of the roof lining has to be removed, then you can get your hand inside the roof lining with the spanner to undo the aerial.  :wink:
« Reply #3 on: 23 April 2007, 10:24 »
When you say you had to swap the conector, are they easily available?
Offline bmx
« Reply #4 on: 23 April 2007, 10:36 »
i just cut the original cable 3 inch in on both and soldered the wires together hey presto  :cool:
« Reply #5 on: 23 April 2007, 10:39 »
Many thanks.  :smiley:
« Last Edit: 04 May 2007, 09:05 by Creepy Coupe »
