Golf mk2
Dead gearbox perhaps - Any ideas??
Topic: Dead gearbox perhaps - Any ideas?? (Read 1856 times)
davidhawkins_78
Valver Bad Boy
22 April 2007, 17:31 »
Ohhh the joys of life!! Just got a new radiator sorted, New tyres and the valver was running like a dream!
Over at my folks today and was turning round in the road; started to move backwards CLUNK as if I ran over something, moved forward after check underneath CLUNK again and gearbox oil pissing out but I couldn't see where?
Haven't got time to look at it till next weekend now too - there's nothing obviously missing or broken. Any ideas what the most likely thing to have died is given the low speed and full lock?
'89 Monza Blue Valver
to quote a VW engineer, "the Mk1 was the prototype, the Mk2, the real thing!"
DarnPB
Formerly Darnpistonbroke
Re: Dead gearbox perhaps - Any ideas??
22 April 2007, 18:01 »
I had the same on another car albeit, rear wheel drive. Turned out to be the diff, a part that is incorporated in these gearboxes.
New gearbox perhaps???
monzablue16v
22 April 2007, 18:09 »
Happened to me as well the Diff is held together by rivets which over time work loose get into the gearbox and shred the box before getting spat out leaving a nice hole in the side of the gearbox
Clunk could be the driveshafts or cv joint thats gone as well
Quote from: AlanD on 24 October 2008, 13:33
Organisys
Old and Slow...
22 April 2007, 18:10 »
snapped diff pin maybe. could be new box time.
Quote from: Mr Blue on 29 May 2013, 19:15
davidhawkins_78
Valver Bad Boy
23 April 2007, 15:01 »
I'm expecting the worse to be honest!! If there's a hole in the casing it's not even worth trying to get it refurbed!
I'm loathed to lob a second hand box in as you never know what you're really getting and I want a proper fix. If you add the cost of a second hand box and the refurb together I bet you're not far off buying one in that state already with a warranty!?
What should I be considering with the worst in mind?
Dave.
Uruk Hai
23 April 2007, 15:38 »
Recon box
davidhawkins_78
Valver Bad Boy
Reply #6 on:
23 April 2007, 15:46 »
Lol - well for anyone else thinking recon box the first place I called quoted £817 for a recon box!!! Ouch . . .
Gambit
Forum addict
Reply #7 on:
23 April 2007, 20:16 »
the clunk is caused by sheared diff rivets get caught up in the diff gears - a good test is to try & push the car back n forward in neutral. if the diff is gone then i will still lock up after pushing it back or forth so far.
done exactly same thing in mine. your very lucky if it hasnt split the casing 90% of them do. it cost me £250 to get my 16v box refurbed with the diff rivets replaced with the proper diff bolt kit.
get your original boxed refurbed is my suggestion
p.s. to anyone else with a 16v box that hasnt went yet. trust me it will. they all do!!! hence why loads of valvers have 8v boxes in them now.
Last Edit: 23 April 2007, 20:18 by Gambit
monzablue16v
Reply #8 on:
23 April 2007, 20:25 »
8v box is better anyway :p
Organisys
Old and Slow...
Reply #9 on:
23 April 2007, 21:38 »
should be able to get a box for approx £500
Golf mk2
