Author Topic: Anyone removed an RCD200 or similar?  (Read 3943 times)
Offline robster23
  • Now a VW Fox Owner.
« on: 21 April 2007, 18:49 »
Hi Guys,
I searched but nothing came up.
Has anyone removed or had dealings with the new RCD200 headunit? I bought a set of 4 keys off of Ebay but I can't get the unit out. I want to connect things to it if possible but it's the first head unit to stump me!
All help greatfully received.
Robster
It's urban right? That means it must be tougher, obviously.... ;-)
Offline tommk3cab
Re: Anyone removed an RCD200 or similar?
« Reply #1 on: 21 April 2007, 18:54 »
can you post some pics of it? the only thing i have heared is this:
http://www.golfgtiforum.co.uk/index.php?topic=9894.0
its about a mk3 but it may be similar, dizzie says, about halfway down the first page about some screws behind the air vents.
« Last Edit: 21 April 2007, 18:58 by tommk3cab »
Offline robster23
« Reply #2 on: 21 April 2007, 19:50 »
Thanks mate.
I'll put pics up - the RCD200 is a VW standard double din unit used in 06 plates forwards I think.
VW supplied no specs, no useful instructions and no method to remove it. Joy!
Offline tommk3cab
« Reply #3 on: 22 April 2007, 22:45 »
god knows, just thought there may be certain similarities. i wouldnt like to start ripping it apart, i had a brand new mitsty, didnt even want to touch it!
Offline s_tether
« Reply #4 on: 24 April 2007, 22:08 »
Hi
The unit in the Golf V is an RCD300 - is this what you mean ? it is quite easy to remove, but some trim removal is needed first.
If you go over to ukmkivs, in the DIY Guides section, there is a detailed instruction page on how to remove / replace it.
Try these pages:
http://uk-mkivs.net/forums/thread/170840.aspx
http://uk-mkivs.net/forums/thread/170547.aspx
Regards
Si
Offline robster23
« Reply #5 on: 25 April 2007, 18:40 »
Thanks man but the RCD300 has rounded corners and the screw mounts - nice guide btw.
The RCD200 has square corners and has four slots, one at each corner which the keys I bought are supposed to fit in!  :angry:
No success thus far.....  :nerd:
Offline Bluefox
  • ...back again!
« Reply #6 on: 27 April 2007, 22:31 »
What do your keys look like?
Bluefox
Current: '84 Golf C 1.9 TDi | '01 Polo GTI | '01 Audi A2 TDi | '83 MG Metro
Previous: '83 GX | '04 R32 | '93 VR6 | '86 GTi 8v | '88 Diesel | '92 G60 | '04 Skoda Superb TDi | '90 GTi 8v | Plus many more!
Project Thread - http://www.golfgtiforum.co.uk/index.php?topic=270683.0
