Author Topic: sterio wiring  (Read 3391 times)
Blue MK2
sterio wiring
« on: 04 February 2004, 14:52 »
Is there any other way to connect the (+) on the car loom?
My headunit flashes when i turn it up with the heater fan on.
(its connected to the heater wire at the moment)
« Last Edit: 04 February 2004, 14:53 by Blue MK2 »
Offline S11EPS
  • No golfs here. Only a C63 mercedes
Re:sterio wiring
« Reply #1 on: 04 February 2004, 15:04 »
Where's the standard supply gone?
The greatest leveller of them all - the Carousel
Blue MK2
Re:sterio wiring
« Reply #2 on: 04 February 2004, 15:30 »
its been binned ::)
Offline S11EPS
Re:sterio wiring
« Reply #3 on: 04 February 2004, 15:53 »
Any supply currently in the car is going to be designed to power whatever it is powering, with a tolerance built in for safety. Hanging a high power head unit off of this supply is going to mean too much current draw, so you need to bring a new one in.
I take it you have a high power headunit thats driving 4 speakers?
What I would do is run a supply of decent guage wire straight from the battery (fused of course) to your headunit.
Alternatively, if you are running a distribution block for amps in the boot, you can run a live (again, of good guage size) from your distribution block to your headunit.
