Author Topic: gearbox oil problem  (Read 676 times)
Offline paultownsend
gearbox oil problem
« on: 17 April 2007, 15:22 »
hope you can help.  changed my gearbox oil today as per instruction in the maintainence section. the car is a 91' 8v pb.  jacked up the passenger side and drained when warm.left to cool and filled up. it took all 2 litres but bear in mind the box was tilted up at an angle.  went for a quick drive down the road to make sure oil was worked in.put the car back in garage all 4 wheels on the floor level, left to cool, and undid the filler hole where about 1/4 litre of clean oil came out. so the box only has a capacity of 1 3/4 litres, not 2 as stated in the faq and haynes?
am i correct? being such a late box i wouldnt have to fill up the speedo hole for the last half litre or so?
it felt so slick on just a 2 minute drive. Paul
modified
just looked at trans code and it reads AUG 0107041
« Last Edit: 17 April 2007, 15:38 by paultownsend »
Re: gearbox oil problem
« Reply #1 on: 17 April 2007, 16:15 »
you'll never get all the old gearbox oil out, so that sounds about right to me :)
« Reply #2 on: 17 April 2007, 16:33 »
thats all good then. i can go to the pub!  il check the oil in a few days and see if it needs topping up. Many thanks Paul
