Golf mk3
hardmonkeys
Droaning Sound
Topic: Droaning Sound (Read 2370 times)
TanK_VW
Here all the time
Droaning Sound
10 April 2007, 13:10 »
Hi all,
First off i have a mk3 1.8 GL (not sure if that matters for diagnoise)
Basically this issue is a droaning sound where about 50mph. I think its coming from the front left wheel, what could it be?
Len
10k hero
Re: Droaning Sound
10 April 2007, 13:37 »
Does it change or go when cornering? Is it worse turning right or left?
www.sas.org.uk
www.the-ace.org.uk
TanK_VW
Here all the time
Re: Droaning Sound
10 April 2007, 13:38 »
It gets worse when turning right.
Len
10k hero
Re: Droaning Sound
10 April 2007, 13:41 »
Then it could be a CV joint on the driveshaft. On the left side. (nearside)
www.sas.org.uk
www.the-ace.org.uk
TanK_VW
Here all the time
Re: Droaning Sound
10 April 2007, 13:43 »
how easy/hard is that to replace? and cost?
Len
10k hero
Re: Droaning Sound
10 April 2007, 14:08 »
Sorry dunno never done a Golf! done loads of other cars!
Its a relatively easy job if you got the right tools, like big sockets and a long bar plus ball joint splitters. And dont forget to drain the gearbox!
www.sas.org.uk
www.the-ace.org.uk
TanK_VW
Here all the time
Re: Droaning Sound
Reply #6 on:
10 April 2007, 14:13 »
haynes manual job then
Len
10k hero
Re: Droaning Sound
Reply #7 on:
10 April 2007, 14:39 »
If it was exactly the same as my Pug I could give ya a step by step. Takes a bout half an hour on that!
www.sas.org.uk
www.the-ace.org.uk
TanK_VW
Here all the time
Re: Droaning Sound
Reply #8 on:
10 April 2007, 14:47 »
would have thought its basically the same principle on most cars..
any idea how i would check if that is the correct issue? any visual clues?
Len
10k hero
Re: Droaning Sound
Reply #9 on:
10 April 2007, 15:42 »
Not really. You can check the CV boot.
I mean generally what you describe its usually CV joint. A wheel bearing drones all the time. And you have the classic opposite side thing. Sound on the left and steer right.
I mean I guess you have checked simple things like tyre pressure and wheel nuts.
www.sas.org.uk
www.the-ace.org.uk
Golf mk3
hardmonkeys
Droaning Sound
