Author Topic: Droaning Sound  (Read 2372 times)
Offline TanK_VW
Re: Droaning Sound
« Reply #10 on: 10 April 2007, 15:44 »
yeah checked that. all fine. i had a feeling it was the CV joint.  is it going to be safe to drive with it like that for 2 weeks as i need payday to come... or is it a do it now job?
Offline Len
Re: Droaning Sound
« Reply #11 on: 10 April 2007, 15:49 »
If its only just started then a couple of weeks should be fine as long as you drive steady and dont rag it rounds corners! :wink: :laugh:
Had both go on a Renault 21 and was fine for 3 weeks and I was doing 70 miles each way all on twisty country roads!
www.sas.org.uk
www.the-ace.org.uk
Offline opel
Re: Droaning Sound
« Reply #12 on: 10 April 2007, 20:43 »
u sure it aint wheel bearing as wen they go they droan. ive only ever heard click from cv joints
Offline Len
Re: Droaning Sound
« Reply #13 on: 10 April 2007, 20:46 »
Thats what i thought at first, but when he said its only when turning.......
www.sas.org.uk
www.the-ace.org.uk
Offline GolfMad
Re: Droaning Sound
« Reply #14 on: 10 April 2007, 21:45 »
hey guys,
reading you thoughts on Tank_Mk3's issue and possibly think I have a similar problem, have noticed a 'clicking' sound every now and again which appears to be coming from drivers side front wheel area, wasnt sure if it was a bracke issue or wheel bearing, but maybe you think it could be a cv joint if its a 'clicky' noise?
(sorry to hijack the thread, but your thoguhts appreciated)
cheers Andy
Offline TanK_VW
Re: Droaning Sound
« Reply #15 on: 11 April 2007, 08:29 »
It gets worse when turning right.
its a droaning sound not a clicking and its there when i get to about 50mph and gets worse when on a bend to the right. is this going to be the bearings?
Offline Len
Re: Droaning Sound
« Reply #16 on: 11 April 2007, 08:49 »
CV joints do sort of click, but its not now and again. Will be all the time during cornering. Its more like a clunk or thud.
Tank yours does sound more like wheel bearings. jack up that wheel and see how much movement there is in the wheel.
www.sas.org.uk
www.the-ace.org.uk
Offline TanK_VW
Re: Droaning Sound
« Reply #17 on: 11 April 2007, 08:51 »
will check tonight.
Offline opel
Re: Droaning Sound
« Reply #18 on: 13 April 2007, 19:15 »
let us know hjow u et on sound slike it will be wheel bearing as that the only thing that can cause droaning noise
