Author Topic: fuel pump wire - where does it go? *pic*  (Read 3081 times)
Offline theruler
« on: 09 April 2007, 18:01 »
just swapped out the fuse box in a mk1 i bought (a very easy 20min job)
for a brand new one. luxury. suddenly all the electrics work!!!!
the fuel pump had been wired to a switch. one wire comes from the ignition somewhere, and one comes from the pic below (the one with the arrow)
now i think this should lead to somewhere on the fuse box. at present it leads to a switch. where should it really go? it's the single side of that 2 into 1 plastic coated junction . . .
the fuel pump relay clicks when i switch the ignition on, so i guess i just gotta get this wire in the right place and it's happy days.
Offline caddyrage
Re: fuel pump wire - where does it go? *pic*
« Reply #1 on: 09 April 2007, 21:49 »
I believe its position 14 on the D black plug mate. Thats where mine is on my caddy, now that its injected  :smiley:
03 ibiza PD 130 sport, smiles per miles!
83 mk1 golf gti, 16v 2L PL
92 mk1 caddy, now stripped for resto
WWW.FENDUBBERS.CO.UK
cambridgeshire vw owners club
Offline theruler
« Reply #2 on: 10 April 2007, 08:35 »
thanks caddyrage i'll check that point and see if there is a wire not connected there  :cool:
« Reply #3 on: 10 April 2007, 13:26 »
check the fusebox faq in the garage section, look under pre-90 mk2 :)
Offline theruler
« Reply #4 on: 11 April 2007, 16:48 »
mine's a 1980 mk1 gti with the early type fusebox
still confused as to where this wire should lead!!!
i don't want to run this on a switch :(
« Reply #5 on: 11 April 2007, 16:56 »
the rear of the early mk1 fusebox is still the same as a pre-90 mk2 I believe :)
Offline theruler
« Reply #6 on: 11 April 2007, 17:14 »
cool beans mate thanks
i will peruse your fuse box journals . . .
Offline kraM
  • It's not the speed, it's the sudden stops...
« Reply #7 on: 20 April 2007, 16:01 »
Look at the picture, see the whit plug, count three wires in, that burnt looking red/yellowish one, that's your kiddy, the one i've just replaced.  You can buy british bike repair connectors to repair the multiplug, they are the only ones that fit, that I have found.  You have to squash them a bit though.
kraM
It's not the speed... it's the sudden stops...
Offline theruler
« Reply #8 on: 21 April 2007, 18:39 »
kraM
thanks kram you rule!!
Offline M41K1T
« Reply #9 on: 22 April 2007, 16:57 »
how much did u pic up fusebox for as i need 1
« Last Edit: 22 April 2007, 16:59 by M41K1T »
