Author Topic: standard mk3 tweeter holders in the dash.  (Read 2171 times)
Offline tommk3cab
« on: 05 April 2007, 15:31 »
has anybody had them out? if so how, because ive wanted to replace them for a while and now they are blown and i need to replace them! i knew this day would come! the actual pods seem to move a bit as though they have to be turned but they dont seem to want to go.
Offline Len
Re: standard mk3 tweeter holders in the dash.
« Reply #1 on: 05 April 2007, 15:56 »
Yea I looked at them and managed to free one side, the nearside, but the drivers side I couldnt budge.
www.sas.org.uk
www.the-ace.org.uk
Offline snaps
« Reply #2 on: 05 April 2007, 16:51 »
on my 1.4/94 they just unscrewed  :huh:
Offline tommk3cab
« Reply #3 on: 06 April 2007, 14:18 »
snaps, which way? mine are really tough?, it may be different because mine ( i should have said ) is a cab but it must be similar.  did you get one side totally out len or just one side of one side if that makes sense?! if you did how? did it need turning, which way if you can remember clockwise or anti?
« Last Edit: 06 April 2007, 14:21 by tommk3cab »
Offline Len
« Reply #4 on: 10 April 2007, 09:56 »
Sorry tom was yonks ago! (years)
I know I had to twist it but cant remember which way. Yes I did get the passenger side out completely. The drivers side wouldnt budge and didnt know whether to turn it the same way as the other side or opposite! :undecided:
www.sas.org.uk
www.the-ace.org.uk
Offline weasel
« Reply #5 on: 10 April 2007, 11:58 »
Are we talking about the same ones? the ones that sit under the grilles on top of the dash? they just lever out with a screw driver, i replaced them with sony speakers from argos that sit straight in, and sound much better.
Offline Len
« Reply #6 on: 10 April 2007, 12:11 »
That was brave of you! (screwdriver near speaker)
definitely had to twist mine!
www.sas.org.uk
www.the-ace.org.uk
Offline tommk3cab
« Reply #7 on: 11 April 2007, 14:07 »
cheers for all your help.  mine seem to twist too, only slightly though, tried a bit of leverage with a screwdriver and it didnt seem the way to go, maybe there are different sorts, my ones are under the grilles on the dash but they arnt speakers as such though, like custom built tweter pods. ill try giving them a bit more force i think, cant hurt, they are blown now anyway!
« Last Edit: 11 April 2007, 14:11 by tommk3cab »
Offline Len
« Reply #8 on: 11 April 2007, 14:18 »
Could ya do me a favour and measure the hole?
Been thinking about putting some mid/tweeters in there for a bit more sound.
I used JBL 202's in my other car. 2 1/2 inch mid/tweets.
www.sas.org.uk
www.the-ace.org.uk
Offline tommk3cab
« Reply #9 on: 11 April 2007, 23:40 »
im pretty sure they are 13cms, thats just by eye though, ill get the tape measure out tommorrow, got the whole pod out today, a screwdriver did the trick, snapped one of the little clips but there is about six so one wont hurt, they dont move much anyway!
complely unrelated question now but, i had the cam belt done when i first got the car and afterwards it made like a constant, but not rythmic squeaking/grinding noise it was like very fast intermittant bursts and it got worse as the car/belt warmed up and continued all through the rev range ( not that i revved it that high as i didnt want to mess it up good, but it wasnt just on tickover!) i took it back to where i had it done and was told the noise would go away after 100 or so miles as the belt needed to wear in and slacken a bit. sure enough it did go away, ive done max 2000 miles since then and today the exact same noise returned, on tickover but went almost as soon as i got in the car to drive off. it sounds like its coming from the bottom of the cambelt, water pump kind of area ( at least it is on a renault!)  any ideas, the belt does kind of look worn again but he said he did the pullys and tensioners so it shouldnt be. got 12 months warranty anyway so im kind of hoping it does snap! brand new engine for me!! na i doubt it, probably just a new belt, but ill have no engine!
« Last Edit: 11 April 2007, 23:43 by tommk3cab »
