Author Topic: standard mk3 tweeter holders in the dash.  (Read 2172 times)
Offline Len
Re: standard mk3 tweeter holders in the dash.
« Reply #10 on: 12 April 2007, 09:19 »
Surely not that big! 130mm thats 5 inches. Yea check please!
Your cambelt thing dont sound right to me. Have fitted about 5 myself and never had any noises.
I would take it back and say to the guy that fitted it that you dont think its right and do a double take on that warranty, make you you know exactly what is covered.
Mind you it could be the water pump and that will be unrelated.
www.sas.org.uk
www.the-ace.org.uk
Offline tommk3cab
« Reply #11 on: 12 April 2007, 20:09 »
tried some spks i had in the holes today, 13cms is right, im going to fit them properly tomorrow, the grille even still fits, with the spks i have anyway, if you have a dremel or that kind of thing you may need to cut off the bit where you would screw the spks down ( the bits you would use if screwing them to a door/pod/parcel shelf) or the grille clips may be blocked but you may be lucky, like me. you wont need to screw them, the grill should do the holding down, im yet to see if the spk cone will hit the grille though, tommorow will tell!
yeah ill take it back to him, he is a friend of the family so he should be sound about it even if the engine does go bang, he has business insurance! he said it was to do with the way the tensioner worked or something, i queried it at the time, he said he set the belt tight to allow for it to slacken, as if it slackened and it was set right then it would then be too slack, if that makes sense. the noise did go away, just like he said, i dont think it is the water pump, i did at first, before i had him check it, when it went away i thought nothing else of it. It is however that kind of water pump clattery noise, but quiet a bit louder. if it was coming from my actual engine id scrap the car, put it that way! when it was first done and the engine/ belt got hot it became like a high pitched whine.
Offline Len
« Reply #12 on: 13 April 2007, 10:00 »
Thanks for that Tom. Will be looking around at what speakers I can fit in there then!
Sounds as if he over tightened the belt then! Should have a tiny bit of slack in it.
www.sas.org.uk
www.the-ace.org.uk
Offline Len
« Reply #13 on: 13 April 2007, 13:09 »
Now I know the size of speakers that will fit in the dash I'm thinking of doing this!
1. Some 130mm components with the mid in the dash and put the tweeters on the A post.
I have a different mounting in mind similar to an instrument pod I've seen.
2. Change the 3 ways I have in the front doors to 2 way Infinity Kappa's and amp them!
Thought I'd add this into here as well (from Car Audio)
www.sas.org.uk
www.the-ace.org.uk
Offline tommk3cab
« Reply #14 on: 13 April 2007, 16:20 »
deffo but len im real sorry and hope you havnt brought any yet but they are 10 cms in the dash, i know i said 13 but i looked at some other speakers i had today and i thought they were 15s, sure enough they were 13s and the ones ive put in today were 10s, you were right 13s are miles too big! hope this hasnt put you out, kappers are solid speakers, the tweeters with them are mint.  have you looked at the dead quick tweeter builds sticky thread in the audio forums? that has got to be done!
