Author Topic: rounded bolts on vibration damper  (Read 2022 times)
Offline DarnPB
  • Formerly Darnpistonbroke
Re: rounded bolts on vibration damper
« Reply #10 on: 04 April 2007, 15:24 »
Neither do I! :laugh:
Offline 83coupe
« Reply #11 on: 04 April 2007, 20:18 »
haha opz, ok heres how its looking. and i found out i have a pulley puller in my garage, so if someone can confirm, ill get it off and finish the job tommorow.
« Reply #12 on: 04 April 2007, 20:32 »
yep just jank off that pulley and you'll be able to get the cover off :)
Offline DarnPB
« Reply #13 on: 05 April 2007, 00:06 »
That is soooo different to mine.
« Reply #14 on: 05 April 2007, 09:43 »
doesn't matter what the pulleys look like, just remove the 4 allen bolts holding em on and pull the pulleys off ;)
Offline 83coupe
« Reply #15 on: 05 April 2007, 19:17 »
big thank you to you guys! got it all back together today. it didnt fire up as the battery run flat before the fuel pressure built up, so lets hope i got the timing marks right  :tongue: ill reprt back tommrow after i have another fiddle
Offline 83coupe
« Reply #16 on: 06 April 2007, 16:13 »
well as i guessed, the timings out lol. Could someone please point me in the right direction for which marks to align.. i would buy a manual but im off work without sick pay with a broken toe  :cry: this is how i have it so far..
Score on vibration damper is inline with the dot on the intermediate shaft, and the dot in the inside of the cam wheel is level with the head surface..
 ive noticed O.T marks on the cam wheel and I/S. should i be using these.. ?
« Reply #17 on: 06 April 2007, 18:29 »
the notch on the crank pulley lines up with an arrow on the cambelt cover, but if you can use the punch mark on the flywheel as its more accurate. Though you need to remove the green bung to see it which can be a pain!
Ignore the intermediate shaft marks, just line the rotor arm up with the notch in the dizzy.
The cam pulley OT marks will line up with the arrow on the inner cambelt cover if you have a later plastic one which is in 2 halves, if you have the single piece metal one you need to line up the punch mark on the back of the pulley with the top of the cam cover :)
Offline 83coupe
« Reply #18 on: 06 April 2007, 20:41 »
cheers jonny, once again you are a fookin legend and saved the day.. fired up stright away  :wink: Ive not put it back on the road yet though, as i've raised one side of the car, but the locking rings are stuck on one of the coilovers so ill be fighting with that next. thanks again mate i owe you one!  :grin: :grin:
« Reply #19 on: 06 April 2007, 20:46 »
good luck :)
