Author Topic: Cheap Coilovers  (Read 2619 times)
Offline jaybv6
  • 03 Mk4 GTTDI PD 150
Cheap Coilovers
« on: 31 March 2007, 09:09 »
Has anyone used these coilovers on their Mk2?  If so how have you found them?
Click Here
Offline Agreeable Slick
  • Unit
Re: Cheap Coilovers
« Reply #1 on: 31 March 2007, 09:28 »
IMO you get what you pay for, why risk it? Suspension is such a vital part of the car.
Offline rowlers
  • I'm back - MK7 GTI
Re: Cheap Coilovers
« Reply #2 on: 31 March 2007, 09:52 »
have to agree - I have had the cheap suspension kits (not the coilies) off ebay, they do the job for the money!
I have just put Eibach springs on and can't believe the difference in the handling/ride of the car!
Offline T_J_G
Re: Cheap Coilovers
« Reply #3 on: 31 March 2007, 11:21 »
hmm i'm tempted with either those or the FK AK budget coilies.
Offline mattp1983
  • Keep it VAG :)
Re: Cheap Coilovers
« Reply #4 on: 31 March 2007, 11:44 »
Well I have the jamex (same as these just different brand) on my Bora, and the ride although firm isn't jarring and its lowered a fair bit, cost me £299 then £100 to fit and allign them from midlandvw. wouldnt pay for fitting on a mk2 though its dead easy. Plus they are stainless steel so wont corrode like FKs. Ok they are not the quality of KWs but they are not the price either. I am happy with them and its my daily.
1989 Golf GTI 8v Tornado Red <br />2004 Bora Highline TDI 180bhp Shadow Blue
Offline jaybv6
Re: Cheap Coilovers
« Reply #5 on: 31 March 2007, 11:46 »
Cause my budget won't stretch to £400-£600.  I want to lower the ride height and stiffen the suspension on a budget.  Most of my cash goes on my family and my house which leaves me little left to modify the golf (bear in mind I've already thrown £700 at my current car getting it back on the road).
Ok, so they aren't gonna be a patch on a £600 setup but how risky can it be?  Ideally I want a second hand Koni/Eibach setup but they are so hard to come by.
Offline mattp1983
  • Keep it VAG :)
Re: Cheap Coilovers
« Reply #6 on: 31 March 2007, 11:57 »
a lot less risky than second hand suspension its not something I would fit to my car. Like I say my bora (my family car) has these fitted, speak to jody at midlandvw, he is a very knowledgible bloke as most people will tell you, he has not had a single complaint about them. He charges £299 with a 2 year guarantee (manufacturers).
I couldnt tell any difference in the build of these to eibach coilovers I have looked at, they are made in the bv hitrac factory in NL, they make suspension for a lot of the big names.
This is how low I am running (well a little more since they settled, this was taken the day of fitting and the ride is really quite good)
Offline rowlers
Re: Cheap Coilovers
« Reply #7 on: 31 March 2007, 12:05 »
if you're not going to lower to the deck, and are not going to adjust ride height once you have it set, then don't bother with coilovers - I was tempted by the cheap coilovers as well!
Buy a set of GAZ shocks off ebay (supposed to be very good - the gold coloured ones are damping adjustable!) and a set of eibach springs, all new mounts and you should still see change from £300. Fit them your self its easy!
My money too goes on my house and family so know where you are coming from -  I too have skimped on suspension and its ended up costing me more in time and £Â£Ã‚£Ã‚£Ã‚£s than if I'd just gone down the eibach and decent shocks route to start with!!!
thats my two penneth for what its worth! :wink:
Offline jaybv6
Re: Cheap Coilovers
« Reply #8 on: 31 March 2007, 12:47 »
Well I'm not going to drop it to the deck as it's my track car but i do want to stop it from lifting a rear wheel 6 inches off the ground when I corner.  I also want something that's going to remain fairly composed and flat in the corners.  I know that Eibachs alone will set me back the better part of £130 (which is basically my budget) but I can fit them with standard shocks.  However if I want to go lower than 40mm I'll need to buy shocks aswell.  I can't afford uprated ARB's and am only using the car on the road occasionally.  So if I want to spend £130 what's the best thing I can do without resorting to spending it on a G-Max setup.  I could stretch to £200 at a push.
As always your comments are welcome.
Offline rowlers
Re: Cheap Coilovers
« Reply #9 on: 31 March 2007, 13:04 »
gmax are actually a very good manufacturer!
They do actually make their own springs etc... and also supply a lot of the leading names, who rebrand tham as there own! (e.g. FK springs and coilovers are actually gmax!) I was also recommended a Supersport Kit, (Should be within ur budget) These are German made so can't be that bad!
I wouldn't go with the Ebay kit it has too much roll for a track car!
If your shocks are in good condition go with the eibach pro kit - you won't be disappointed!
