Author Topic: EXHAUST MANIFOLDS  (Read 1129 times)
Offline richard s
EXHAUST MANIFOLDS
« on: 29 March 2007, 21:02 »
I HAVE A 2.0 TALL BLOCK IN MY GOLF AND MY DOWNPIPE IS STARTING TO BLOW I AM CONSIDERING A 4 BRANCH MANIFOLD AND HAVE HEARD THAT A MK THREE GOLF 2.0 8V 4BRANCH WILL FIT BETTER THAN A MK 2 GTI 8V DUE TO TALL BLOCK BEING FITTED.
HAS ANYONE HEARD THIS OR DONE THIS TO THEIR GOLF
MINE IS A 1990 8V DIGI IF THIS MAKES ANY DIFFERENCE ALL ADVICE ON THIS MATTER IS APPRECIATED AS I DONT WANT TO BUY A MK2 OR MK3 MANIFOLD AND IT NOT FIT AS SODS LAW I WILL PACK THE WRONG ONE CHEERS
Offline Mew
Re: EXHAUST MANIFOLDS
« Reply #1 on: 30 March 2007, 16:04 »
Do you have the mk2 head fitted or the mk3? I've got a feeling that the spacing of the ports is different so you would need to choose the manifold based on the head.
That may well be completely wrong so don't take my word for it, it's just no one else answered!!
Offline richard s
« Reply #2 on: 30 March 2007, 21:12 »
its a2.0 bottom end with a 1.8 pb head
Offline GT3 Turbo
« Reply #3 on: 31 March 2007, 03:22 »
the heads the same as 1.8L on most models before 1998... tall block just means the crank throw is more, i.e. engine stroke is longer...
any 8v mk2 performance manifold will fit it
Offline chrishodge06
« Reply #4 on: 31 March 2007, 13:21 »
unless you got the audi bubble block the 2.0l block is about 17mm taller ive ordered a ashley mild steel manifold £162 ill let you know if it fits when i get and how to make it fit if it doesnt it i know a 16v front mounts ment to help as it tilts the engine back a bit i wouldnt bother with a stainless one they are dearer and prone to cracking and if you need to mod it by weilding it or heating it up to bend it.you will weaken it and it will crack stainless is harder but more brittle if you know what i mean
Offline richard s
« Reply #5 on: 01 April 2007, 20:41 »
i was flicking through some old golf mags and there was one bit that said a 4 branch creates a lot more noise and a better route is to fit a mk2 16v downpipe as mine is quite loud at the moment i dont need it any louder so has any one got any other advice for me to mull over cheers
« Reply #6 on: 01 April 2007, 23:53 »
you could get the standard manifold ported and look in to useing a 16v or g60 down pipe im sure gtijoe done this  :wink:
