Author Topic: SUB....AMP....SUB....AMP  (Read 3971 times)
Offline perd999
« on: 31 January 2004, 19:03 »
hey
im newwith ICE and im gonna ask stupid questions nw, first of all to fit a sub wot do i need ?obviosly an amp connected to the battery and them do i just connect the sub to that ? and shud my head unit hav a power out or something (like circular plugs)?plez help?
thnax
Offline db Sam
Re:SUB....AMP....SUB....AMP
« Reply #1 on: 31 January 2004, 19:10 »
to run a sub and amp you will need to have a power suply from your bat with a fuse suited to your amp. and earth lead from your amp to chasis. a remote lead from your h/unit along side a set of phono (r.c.a.) leads. and speaker cable from your amp to the sub(s).
kits are available and works out alot cheaper than buying everything seperatley !
good luck
Offline Dizzie
  • Make friends with your fast
« Reply #2 on: 31 January 2004, 20:45 »
and a box to put your sub in ;D
free air ones are pants btw.
Offline perd999
« Reply #3 on: 07 February 2004, 21:07 »
yeh....do u no where i can see any gd head units to buy ....or do u recommend ne.......is it two or one wire from unit to amp
Blue MK2
« Reply #4 on: 07 February 2004, 21:29 »
cheap units....
www.mcs-direct.co.uk based in Lesta
one remote wire from the unit to the amp
set of pre out leads (some come with a built in remote wire in the centre) these go from the unit to the amp and carry the audio signals :)
