Author Topic: 1300 Fuel Pump  (Read 1235 times)
Offline Ricky
1300 Fuel Pump
« on: 27 March 2007, 21:54 »
In need of some help.
Does the fuel pump have a seperate plunger, as I bolted it on to the head and the rod coming from the pump doesn't reach the camshaft and it seem theres should be another bit for it to reach the cam?
Any help would be great cheers!
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
Re: 1300 Fuel Pump
« Reply #1 on: 27 March 2007, 21:55 »
natch mate tis all one piece? got a photo of what youve got there atm?
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
Offline Ricky
Re: 1300 Fuel Pump
« Reply #2 on: 27 March 2007, 22:02 »
Best one I got
Don't laugh at the state of my engine, its a work in progress!
« Last Edit: 27 March 2007, 22:07 by Ricky »
Re: 1300 Fuel Pump
« Reply #3 on: 27 March 2007, 22:20 »
looks right to me mate!  :smiley:
Quote
Re: 1300 Fuel Pump
« Reply #4 on: 28 March 2007, 09:22 »
are you sure its bolting down flush, and that its the right pump for your engine?  My dad had to replace the pump on his 1.3, and I remember he had to grind it a bit so it would go on...
Re: 1300 Fuel Pump
« Reply #5 on: 28 March 2007, 09:50 »
i remember when i had mine off, when we thought it had died john.. they were the same, then again, it was between 2 2G engines, and there is the HZ/HK etc isnt there in 1.3? oh and theres an o ring between but thats it? that surely wouldnt make it stand proud
Quote
Re: 1300 Fuel Pump
« Reply #6 on: 28 March 2007, 10:14 »
No I meant is it a 1.6/1.8 carb pump ;)
I don't know exactly why my dads pump didnt fit, I assume the casing hit something?
Re: 1300 Fuel Pump
« Reply #7 on: 29 March 2007, 01:14 »
I rememeber you mentioning about your da having that problem i'm sure, cause his pump failed.
And ah, good shout, I see your point now  :grin:
I've got a spare, i think, 1.3 pump form a 2g engine, sat here.. if it may b of any use, I may flog it off  :huh:
Quote
Offline Ricky
Re: 1300 Fuel Pump
« Reply #8 on: 30 March 2007, 19:40 »
Its the pump that came off the engine and it ran before.
Haynes show a picture of a plunger being inserted before the pump.
Re: 1300 Fuel Pump
« Reply #9 on: 30 March 2007, 20:36 »
etka lsits an instermediate cam follower.. maybe thats whats gone awol, you sure it hasnt fallen inside or something  :undecided: i gotta do ym rocker gasket, ill take a photo inside when its open..
Quote
