Author Topic: Ruddy ticking noise  (Read 1132 times)
Offline momojones
Ruddy ticking noise
« on: 27 March 2007, 21:35 »
i've got a 91 plate 8v , she's getting on a bit , 145K on the clock . When i accelerate between 2000 - 2500 revs , i get a ticking noise from my engine , anyone had this , or is it purely because it's been around the block a few times ?
Offline Organisys
  • Old and Slow...
Re: Ruddy ticking noise
« Reply #1 on: 27 March 2007, 21:39 »
The most likely culprit is hydraulic tappets, does it do it most when you first start the engine from cold ?
Offline momojones
« Reply #2 on: 27 March 2007, 21:47 »
no mate , does it all the time , no matter if it's been running for five minutes or five hours . Hydraulic tappets , sounds nice and pricey .
Offline Uruk Hai
« Reply #3 on: 27 March 2007, 22:01 »
Offline momojones
« Reply #4 on: 27 March 2007, 22:11 »
cheers uruk , i'm stabbing guess that it's a garage job to change em . My knowledge of DIY goes as far as changing a starter motor .  :grin:
Offline DarnPB
  • Formerly Darnpistonbroke
« Reply #5 on: 27 March 2007, 22:34 »
Its not a big job if you follow the Haynes properly. Just don´t c*ck up the cam timing!! :smiley:
Should not take much more than a couple of hours for the un-initiated.
« Reply #6 on: 28 March 2007, 09:21 »
yeah not too bad, whip the cam out and replace, refit cam, drive :)
only thing you need to worry about is you need to remove/replace the cam clamp bolts in the right order, and refit the cam clamps exactly the same as they came off!
Before you do that though, try doing an oil flush and refill with synta silver and a genuine or decent quality oil filter, you can get these from vwspares as well :)
Offline momojones
« Reply #7 on: 28 March 2007, 19:39 »
cheers for the reply people , i was told about the engine flushing today . Shall give that a wee try before delving into my engine bay with a spanner and no clue !!!
Offline dadrathers
« Reply #8 on: 30 March 2007, 23:13 »
Yeah I had a ticking tappet but only on start up when she had been sat for a while (all weekend). So I did the engine flush jobby, new oil and filter. Now I get the tappet noise EVERY time I start. Derrrr!
