Hi.. what's the word on this problem..?
Just fitted new suspension to my Mk3 8v, Boge turbo strut/shocks and Eibach pro's,
The assembled struts did not hold the springs really tight, they were not exactly jangling about either but you could turn them slightly!
Looking around the forum i can see now that this is a likely MOT failure! These springs are obviously shorter than the original items, supposed to lower 30mm but at the moment there isn't any significant drop noticable..that is intil it all beds in after a while.. which might mean my springs are going to be even looser when it's jacked up off the wheels??
It seems the Boge/Eibach combo is quite commonly used, but these and some other systems must present the same issue i imagine..
By the way i used new VW top mounts..
As for the handling it's just what i wanted, very much improved without being too edgy
Like to hear about anybody's experiences or problems with loose springs and MOT time..
Christo
