Author Topic: could you fit a superchager to a mk3 1.4?  (Read 4888 times)
Offline golfmk3
« on: 15 March 2007, 20:22 »
when i get my new golf im going to fix the stuff under the 'hood but i'll need a lil' OOOOMPH coz my mum will drive it for a while and her driving style wont put up with 60 bhp also how much do the things cost
Offline Bazzer
Re: could you fit a superchager to a mk3 1.4?
« Reply #1 on: 16 March 2007, 07:27 »
no.
 :smiley:
Bazzer
Offline Len
« Reply #2 on: 16 March 2007, 09:42 »
Could fit a turbo!
But why?
Why not go for Nitros?
www.sas.org.uk
www.the-ace.org.uk
Offline golfmk3
« Reply #3 on: 16 March 2007, 19:41 »
i am no way puttin nitros in it its expensive and my mum would use it all the time, how hard are turbos to fit compared to superchargers  :undecided:
Offline Len
« Reply #4 on: 16 March 2007, 20:20 »
Not a DIY job! Unless you have tube bending equipment and are a very good welder. A big bore pipe has to come out of the exhaust to power the turbo.
www.sas.org.uk
www.the-ace.org.uk
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #5 on: 30 March 2007, 11:28 »
Im about to fit a turbo to my 1.4 its going to be my spring project.  The engines coming out for a full rebuild with stronger components etc... I don't want to run massive boost but it will certainly give it a kick up the backside.
You can fit a supercharger to a 1.4, as well as a turbo.  It does however depend on what engine it has.
Mine is the AEX 1.4 which is also used in the polo and seat ibiza.  its diffrent to the usual Vdub engines (mounted differently)  So supercharging isn't easy.  Its MPI injection as well so its a plastic manifold which wont take much boost before it splits or something.  Im not sure if it will be worth making up a metal one (pricy) or just keeping the boost low and have done with it.
If you want more info feel free to PM Me.  I have worked out everything i need to for my engine and have all the prices etc...
HTH  :wink:
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline DubFan
« Reply #6 on: 30 March 2007, 13:20 »
It'd be cheaper and easier to swap the engine over.
If you want to stick with a 1.4, you could get a 1.4 16v engine from a Polo, which has 100bhp. Or you could get a 1.6 16v from the Polo or Lupo GTI.
Getting a 1.4 16v from a crashed polo would probably cost a few hundred for the engine, then a few hundred more for the fitting, meaning the bill would be at least a grand, and would that really be worthwhile. Once the mods are declared to the insurance it'd be no cheaper than insuring a GTI, and you could just buy a golf GTI for a grand anyway.
Offline Rmachines
« Reply #7 on: 30 March 2007, 15:09 »
Yea. Theres only one reason i'm sticking with the original engine and that is because i'm curious as to how much u can get out of it.   Its a mission to turbo charge the stock engine rather then to make the car faster.  I don't intend on keeping it all that long, i have my GTI and GT-Four for power so this is just for fun.   :laugh:
Offline golfmk3
« Reply #8 on: 30 March 2007, 21:48 »
i'd never find a gti in the same colour does anyone know what thats called its LB6T    EdIt: by the way i checked and ive got the ABD engine..  also  when did they start doing colour coded bumbers?
« Last Edit: 30 March 2007, 22:19 by golfmk3 »
Offline neil_1821
« Reply #9 on: 30 March 2007, 22:31 »
started the colour coded bumpers in 96. i know cause mine are colour coded, and mines only a 1.4, i wouldnt advise putting a turbo on it unless you are going to rip it out and rebuild with stronger components, wouldnt be the first standard engine i've seen blow a whole in the black cause they put a turbo on a standard engine, the components wouldnt be able to take the temperature or the beating.
I'd either say do an engine swap with something a bit bigger with more kick, or just save your pennies and buy a VR6. :smiley:
