Author Topic: Running power cables for subr in a Mk 4 GTi TDI  (Read 2758 times)
Offline dinkyd
« on: 13 March 2007, 16:53 »
Hi All,
I've got a mark4 golf TDI GTI (150bhp 53 reg). I'm keen to get the sounds wired in but can't find a gromet to run the power cable. Can someone point me in the right direction, cheers.
Pics would be usful if you've got them.
Thanks
Offline gtisteve
Re: Running power cables for subr in a Mk 4 GTi TDI
« Reply #1 on: 13 March 2007, 21:52 »
No need for gromet. Below the steering wheel, next to the fues box, if you take off the trim you will find a positive, an earth and an ignition point where you can take all the power you need for your sounds  :wink: sorry no photos Hope this is clear
Offline dinkyd
« Reply #2 on: 15 March 2007, 09:29 »
Cheers Mate your a diamond. :wink:
Offline tommk3cab
« Reply #3 on: 15 March 2007, 22:55 »
what amp are you plannning to install? and where is it going, you may want to reconsider using those points.
« Last Edit: 15 March 2007, 22:57 by tommk3cab »
Offline dinkyd
« Reply #4 on: 16 March 2007, 16:37 »
Its an alpine amp I'll check which one..... what would you suggest?
Offline tommk3cab
« Reply #5 on: 16 March 2007, 18:50 »
« Last Edit: 16 March 2007, 18:53 by tommk3cab »
Offline tommk3cab
« Reply #6 on: 16 March 2007, 18:52 »
not got a clue im afraid, never done a mk4 if you give me a while i could find out because someone i know has one, those points though, seriously if its a half decent sized amp as alpines normally are, in fact almost any amp will need a proper power cable of a given thickness. because of this all the wire to the battery needs to be this thickness or you will effectivly get like a bottleneck effect, the standard wiring will not be thick enough i suspect. this is where i have gone in my mk3.
under the car may be an option if a grommet is really unavailable, ill look into it.
Offline Bluefox
  • ...back again!
« Reply #7 on: 23 March 2007, 21:42 »
As mentioed, running amp power feeds from sources other than the +ve termpinal is a bad idea. That said, most (recent) Skoda's seem to have a "power bar" on the bulkhead. Is this the thing you're referring to, Gtisteve?
Sorry, I've not worked on a mk4 myself. Although one of the guy's I work with runs a couple of Audiobahn subs via an amp with 4awg wiring and he's got a drect feed to the battery is his Bora, so it's obviuosly possible to get a wire through.
Bluefox
Current: '84 Golf C 1.9 TDi | '01 Polo GTI | '01 Audi A2 TDi | '83 MG Metro
Previous: '83 GX | '04 R32 | '93 VR6 | '86 GTi 8v | '88 Diesel | '92 G60 | '04 Skoda Superb TDi | '90 GTi 8v | Plus many more!
Project Thread - http://www.golfgtiforum.co.uk/index.php?topic=270683.0
