Author Topic: Ignition switch removal  (Read 1014 times)
Offline Mr Blue
« on: 12 March 2007, 16:34 »
Hi guys
the mk2 keeps conking out and IT IS the igiition switch.
I just had the steering colum out and its comes out suprisingly easy.
Ive read that you need to drill a 3mm hole to get the switch out of the housing?
I dont have a clue where to drill.
Anyone have a pic for me? or a how to guide? :embarassed:
thanks
Blue
« Last Edit: 12 March 2007, 19:05 by Mr Blue »
Offline Mr Blue
Re: Ignition switch removal
« Reply #1 on: 12 March 2007, 19:07 »
ok just found this..
http://www.4130-products.com/step/ign/index.htm
might wanna sticky it  :smiley:
Offline VapourTrails
« Reply #2 on: 12 March 2007, 19:29 »
did you have to drill anything? looked like just a screw holding the barrel in there i never managed to get passed the steering wheel bush some sort of spacer to make the steering wheel fit right.
Offline Mr Blue
« Reply #3 on: 12 March 2007, 20:10 »
That guide says to remove the lock washer your on about. I didnt get that far
Doesnt look like you need to drill anything tbh :rolleyes:
Im having a go tomorrow if i manage to track down a new ignition switch.
If it doesnt start in the morning then im not going work. (hope it doesnt start) :tongue:
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
« Reply #4 on: 12 March 2007, 22:07 »
jsut for the elccy switch its a scre on the inside edge of it, and it slips out.. only if you wanted to change the actual barrel itself would you need to drill  :smiley:
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
Offline Mr Blue
« Reply #5 on: 12 March 2007, 22:20 »
gotcha
chers mate.  :cool:
Offline Mr Blue
« Reply #6 on: 13 March 2007, 21:43 »
That was piss easy  :laugh:
took 25 minutes.
Just used a long thin flat head screw driver to undo the phillips screw
out with the old. in with the new and it fired up without cutting out :cool:
the screw (crap pic)
chers for the help
