Author Topic: Mk2 Starting problems, Battery  (Read 1938 times)
Offline MK1_BOY
  • Low Low bored out MK1 Golf GTI Campaign.
« on: 28 January 2004, 13:12 »
If the Battery, Alternator and belt have been replaced, works ok for a few days then wont start, only if you jump it, what could the problem??  Have tried tightening the belt but still keeps dying....  Could it be te fact it is only driven about 4 miles a day???  Please help as its doing my head in, cheers
Race ya...
Offline danhock
Re:Mk2 Starting problems, Battery
« Reply #1 on: 28 January 2004, 13:16 »
might be worth checking the Alernator is working properly... Test the terminals on the Alternator.. When running you should get about 13-14 Volts... When engine is off you should see about 12V.
All opinions expressed in this mail are wholey owned by danhock and are not representative of golfgti.co.uk or it affliates.If you disagree with my comments please note that i do not give a f**k ?2005
Offline MK1_BOY
« Reply #2 on: 28 January 2004, 13:45 »
Is it possible that it if faulty even though its only 3 weeks old....
Race ya...
Offline mk1
« Reply #3 on: 28 January 2004, 19:51 »
Are you sure that something is not draining the battery overnight?. Check the charge rate as said, but check the voltage at the battery terminals. This will rule out any bad connections on the alternator +ve to the battery or engine earths. When checking the charge rate note the voltage, then put a jump lead from a good earth point on the engine to the earth terminal on the battery then see if the charging voltage increases. If it does (had one at the weekend ;)) check all the earths and cable crimped ends v carefully. Also check the +ve cable carefully, esp where it bolts to the starter solonoid. Good luck.
Steve.
Offline MK1_BOY
« Reply #4 on: 29 January 2004, 20:46 »
Dont think anything is draining it, only got an Imob, no alarm or Facny Stereo...  I'll giv it a try...  Cheers guys!!!!!   ;)
Race ya...
