Author Topic: mk2 16v losing power and juddering  (Read 1705 times)
Offline justgota16v
« on: 05 March 2007, 17:15 »
Hi,
   got a problem. my 16v, after it's heated up (but not neccesarily overheating) likes to judder violently and lose a good few 100 rpm for a second or 2 at a time. it seems worse if i'm in slow traffic, to the point where it can cause a stall-again, the temp gauge needle can just be at the 1st mark after the 1/2 way point. when it's happening and i accelerate, it kangaroos pretty violently, but if i ease off, it's not as pronounced.
   1 thing i've noticed is that when it happens, the fuel pump sounds like it's sucking air. and it is more likely to happen, but not exclusively, when the fuel tank approaches empty. it has done it on a half tank before. not sure if the air-sucking sound could be a cause or an effect.
  any ideas?
Ta,
Chris.
Offline benmk2
Re: mk2 16v losing power and juddering
« Reply #1 on: 06 March 2007, 11:10 »
I ve had similar, check whether your tank is dinted and check the fuel pressure good luck
Offline gusto
  • 16v gti baby
« Reply #2 on: 08 March 2007, 17:45 »
had the same thing and it was the fuel pump in the boot lokated under a plate from in the boot  think its name is lift pump or somthing like that got a new one and never done it again . on mk 2s you have to fuel pumps one under the car and other one you get to it from the boot but its in the tank  :wink:
Offline justgota16v
« Reply #3 on: 16 March 2007, 18:54 »
Cheers, guys!
Will let you know.
Offline Uruk Hai
« Reply #4 on: 16 March 2007, 19:10 »
If the lift pump is the problem then get it changed a.s.a.p  because if its lest it can end up buggering the under car fuel pump and they ain't cheep  :smiley:
Offline sc
« Reply #5 on: 17 March 2007, 08:30 »
could be lots of other things to though,
sh!tty injectors?
Vacum leak?
I've had many problems with my 16v since i've had it and 2 months dwon tghe line i'm just about happy with the way it runs. I've replace injectors, vacum tubing (most of it was buggered) and lots of other bits and bobs. get yourself a haynes manual and check the pump using that method.
just need to get it set up properly.
Offline tom26
  • team chumpy.
« Reply #6 on: 22 March 2007, 16:58 »
mine failed an MOT on this. expensive new, but i got a 2nd hand corrado unit that will fit a golf (minus plastic case) for £30.
