Author Topic: speedo problems  (Read 1501 times)
Offline vicky
speedo problems
« on: 26 February 2007, 13:21 »
hi guys & girls, for the past week my speedo has been playing up. when i put my foot down my speedo jumps up and down all over the place, i read a a topic that said if you disconnect the battery for 15 mins it will reset the ecu for the rev counter, is that the same for the speedo??  i have had my diagnostics done and it came up with no errors.
Offline Len
Re: speedo problems
« Reply #1 on: 26 February 2007, 13:25 »
Yea worth a try disconnecting the battery! If not try the connectors or the sensor
« Last Edit: 26 February 2007, 13:31 by Len405 »
www.sas.org.uk
www.the-ace.org.uk
Offline vicky
Re: speedo problems
« Reply #2 on: 27 February 2007, 11:00 »
no luck! disconnected battery for 30 mins but still doing the same thing.  if i am going 30 and put my accelerator down the speedo jumps up and down sometimes to 120!! but sometimes it does not do it, it jumps a little bit.
Offline Len
Re: speedo problems
« Reply #3 on: 27 February 2007, 11:17 »
Either a faulty connection, might be loose, so movement changes cause a flutter.
Or the Hall sender is developing a fault.
www.sas.org.uk
www.the-ace.org.uk
Offline vicky
Re: speedo problems
« Reply #4 on: 27 February 2007, 11:24 »
do you know where abouts the connection is so i can have a look tonight?
Offline Len
Re: speedo problems
« Reply #5 on: 27 February 2007, 11:28 »
Might be very difficult! Its down on the diff above where the driveshafts come out.
So back of engine, watch the manifold it stays hot a long time!
Not looked myself so may not be able to see it from above. I looked at my Bentley manual for the location.
www.sas.org.uk
www.the-ace.org.uk
Offline vicky
Re: speedo problems
« Reply #6 on: 27 February 2007, 11:33 »
ok cheers, will have a look later, and can i just ask, have you got a bentley? sorry to be so nosey
Offline Len
Re: speedo problems
« Reply #7 on: 27 February 2007, 11:36 »
Yes I have a Bentley manual on disc that I got off knightrider. Dunno if he is still selling them.
www.sas.org.uk
www.the-ace.org.uk
Offline vicky
Re: speedo problems
« Reply #8 on: 27 February 2007, 11:38 »
oh so you dont have a bentley car,was gonna ask what its like to drive, would love to drive 1
Offline Len
Re: speedo problems
« Reply #9 on: 27 February 2007, 11:45 »
Have driven one about 30 years ago! And that was like driving an unresponsive tank!
I guess the latest models are much better!
I couldnt afford a Bentley! :laugh:
www.sas.org.uk
www.the-ace.org.uk
