Author Topic: Vag-Com Ver409.1 Hack  (Read 16859 times)
Offline freakydeakie
« on: 21 February 2007, 15:09 »
Turn your trial version into a fully registered version.
Copy link below into your browser and download file.
LINK NOW REMOVED - SEE MY OTHER POST FOR VERSION 311.2
Must have Vag-Com Installed 1st
Run Hack and select directory where Vag-Com is installed - hit start and bravo - full registered copy.
ENJOY!!!!!!!!!!!! :wink:
« Last Edit: 02 March 2007, 09:46 by freakydeakie »
Offline EvilScotsman
Re: Vag-Com Ver409.1 Hack
« Reply #1 on: 22 February 2007, 06:58 »
Cheers  :cool:
"Handheld OBDII Scanner"
« Reply #2 on: 25 February 2007, 20:18 »
Grab it while you can - after the end of the week I will have to shut down the FTP Server
« Reply #3 on: 25 February 2007, 20:25 »
thats a peach mate im surprised no-one else has been here! Cheers for hosting it - I realised it was from a private source when I downloaded it. Your a star  :cool:
Offline GolfMad
« Reply #4 on: 27 February 2007, 21:39 »
freakydeakie,
thanks for the info, i downloaded the update and seemed to be successful however when i ran the vag-com on my golf it picked up the two existing faults im aware of but still insisted i needed the full version in order to tell me what exactly the faults are? anything ive done wrong or indeed need to do extra? cheers andy
Offline kr1s77
« Reply #5 on: 28 February 2007, 05:34 »
can some one email me a link so i can get the trial version pls
ASV 1.9 TDI 110
Offline GolfMad
« Reply #6 on: 28 February 2007, 08:18 »
got it sorted and now registers as the full monty - thats great many thanks freakiedeakie,
Kris, the link your after is http://www.ross-tech.com ; download the shareware 409.1 or 311.2 for free or purchase the registered version from Ross-Tech's webside.
Cheers Andy
« Reply #7 on: 28 February 2007, 21:13 »
Hey Golfmad - Just recieved my cable today, loaded the hack which said it was a registered version. Done a scan on the ABS and its gone back to saying I need to activate it.
Are you sure that you managed to get the hack fully working, as now I'm abit sceptical as to whether the hack works or not.??
« Reply #8 on: 01 March 2007, 01:16 »
if the cable is a proper ross tech one it will activate the software anyway wi no hack but they are $350 (£175 at home) each.
Try running the crack again wi the cable connected. ( I assume its an ebay cable)
Offline GolfMad
« Reply #9 on: 01 March 2007, 12:45 »
hi yes, thats exactly what I did.
loaded the hack but didnt seem to register, re-started machine, plugged the lead in(from ebay seller) and re tried the hack, checked the vag-com details and it says its fully registered/activated. thats the easy part the difficult part was figuring out getting the inetrface port sorted on my laptop, cos the instructions from the website are pants.
good luck, b a shame if you cant get it sorted when you put me and others onto this!!
