Author Topic: Vag-Com Ver409.1 Hack  (Read 16860 times)
Offline freakydeakie
Re: Vag-Com Ver311.2 Hack
« Reply #10 on: 02 March 2007, 09:29 »
OK for all of you that are having trouble getting the 409.1 version to register as a full working copy, heres a new link to version 311.2, with a working hack.
http://www.thecracks.us/search.shtml?q=Vag-Com
Download the file VagCom v311.2 Keygen
The file is zipped up. Once unzipped, run the file - release3112n2.exe which will install Vag-Com.
Copy and paste the file tst.bin into the newly created vagcom directory.
Run the vagcom program and when it opens select "About"
Double click on the serial number and copy it.
Run VagComKeyGen311.2.exe and paste the serial number into the box, which will then give you a key.
Copy the key and paste into the "licence number" box in Vag-Com software and click activate.
This hack works 100%
Cheers - enjoy  :wink:
freakydeakie
« Last Edit: 02 March 2007, 09:43 by freakydeakie »
Offline EvilScotsman
Re: Vag-Com Ver409.1 Hack
« Reply #11 on: 03 March 2007, 06:53 »
I used the hack and it worked, however I got a proper ross tech cable from a wholesale supplier for myself and needed version 607,  got it from ross tech site, installed it and it said my status was "licence revoked" - it recognised the hacked version already on disc!
I had to delete all, clean entries out of the registry, then reinstall 607 and the cable i have then auto-registered and activated fully when I ran it on the car.  All good now but be warned if you get a genuine cable it will lock you out if you have used the hack first.
"Handheld OBDII Scanner"
