Author Topic: OIL for 8V GTI/ Valve Stem  (Read 1101 times)
StephenEggo
« on: 20 February 2007, 21:23 »
Hi guys just wondered what oil to put into my 1991 8v gti. Its done 140,000 now and is currently running on duckhams 10-40 semi sythetic.
The engine does use oil around 1 litre to every 1.5-2k miles. I think the valve stem oil seals are maybe showing signs of wear.
Anyway the car is being serviced on thursday and I am wanting to try a different oil. I was thinkiing along the lines of castrol gtx magnatex 15-40. I heard the vw stuff is pretty good as well but I was thinking that 10-40 maybe a little thin if the car is using oil.
I have also just started to notice shades of blue smoke emitting from the exhaust when the engine is reved when cold. Could this be serious?
« Last Edit: 21 February 2007, 08:20 by Stevy »
Offline cняis
Re: OIL for 8V GTI/ Valve Stem
« Reply #1 on: 21 February 2007, 01:02 »
sounds like valve stem seals
Offline fused
« Reply #2 on: 21 February 2007, 04:10 »
There might be an additive to help old seals? otherwise I use cheap halfords oil.... well she drinks so much :shocked: ! Seems a waste of money to put the good stuff in, I'll put that in after the rebuild! Not long now! :grin:
Offline jaybv6
  • 03 Mk4 GTTDI PD 150
« Reply #3 on: 21 February 2007, 08:03 »
I buy Vauxhall's Semi Synth 10w40.  Mainly as I have a trade account at Vauxhall and the oil only costs me £8 as opposed to Halford own which costs nearer £20 :wink:
StephenEggo
« Reply #4 on: 21 February 2007, 08:21 »
would anyone recommend putting 15-40 in opposed to 10-40?
Offline Mart8V
  • I really should know better by now.....
« Reply #5 on: 21 February 2007, 11:07 »
I use the Synta Silver (VAG stuff) religiously.  Good value from GSF and also a genuine filter with the non-return valve in it.
Does sound as though the oil seals may be on the way- not a huge job but worth doing.
Offline takethefifth
« Reply #6 on: 22 February 2007, 14:19 »
No, i tried it, no difference. The 40 is the viscosity anyways so you would need a 10/50 or 15/50 if you wanted to try a thicker oil.
