Author Topic: where can i get a second hand or new auto window motor?  (Read 3771 times)
Offline Ciaran
need one for drivers side what sort of price i am likely to pay 4 a new one! or even a second hand one if someone is selling one!
sorry to put this in here just thought it would be noticed more.
Offline Gambit
Re:where can i get a second hand or new auto window motor?
« Reply #1 on: 26 January 2004, 11:48 »
i paid ?25 each for mine
ring round a few VW scrappies, there is a couple listed in the good guys forum
piece of pish to fit
Offline Ant
Offline Ciaran
« Reply #3 on: 27 January 2004, 13:34 »
will that one on ebay fit late and early model mk2 16v as mine is a 1991 J?
Offline Ant
« Reply #4 on: 27 January 2004, 13:46 »
AFAIK that's will fit any non quarter light models, which should include you.
However winning anything on ebay for the right price is hit and miss, get a quote for the part you need (give these a try http://www.gpcvwaudi.com) incuded p&p and make sure you don't pay more on ebay for what your after, and note this items is ?8.45 p&p
As you just need the motor (assuming can be sold seperately) you'll be up against people after the whole thing, which means their willing to pay more.
« Last Edit: 27 January 2004, 13:47 by DakoYam »
Offline Ciaran
« Reply #5 on: 27 January 2004, 13:52 »
to tell u the truth iv not even looked in the door to see how much of the mechanism is still left!
Offline Gambit
« Reply #6 on: 27 January 2004, 14:04 »
Ciaran, do any of your windows work? first thing i would check for is dud window switches
if one window works, then take the switch out and swap it around to see if both switches work
if both switches work then proceed to step 2 ;)
dismantle the door card, pretty easy to do, 4 screws on the card & two on the door handle
you'll probably need to take away the rubber membrane to get at the motor (good idea to replace these also when the cards are off)
check the connections to the motor, if you have a multimeter check that there is power getting to the motor itself
next step. while tapping the broken motor with a hammer try operating the switch, they sometimes just stick due to lack of use, and a couple of knocks free's them up
still dont work? then it must be banjo'd - get a replacment motor - u need the full assembly including runners - from a late spec golf i.e. not qtr panels
ring round VW breakers and get prices of them, you can get them for ?25
peice of pish to fit, 3 bolts on the motor, 4 on the runner, and 2 holding the glass to the runner
Offline Ciaran
« Reply #7 on: 27 January 2004, 15:01 »
cheers mate
ur a mind of information how long have u owned golfs for and how many have u owned!
Offline Ciaran
« Reply #8 on: 27 January 2004, 15:02 »
cheers mate
must say though the switch itself does not glow when the light are on if that is any help?
Offline Gambit
« Reply #9 on: 27 January 2004, 15:12 »
the switch should glow even if the window motor doesnt work, do both of them not glow?
if it dont glow then there is no power to the switch
not sure if there is a fuse relating to them or not, ill need to check it out tonight
they just pull out anyhow, give the contancts a clean up - i have a spare one in the house somewhere you can have if you find it is a dud switch
this is my first golf, bought it in Aug 2002 - took a while to learn the basics, but a haynes gives you a good overview on the car itself, then the rest is just what you pick up through problems you or others have had.
