Author Topic: where can i get a second hand or new auto window motor?  (Read 3768 times)
Offline Ciaran
Re:where can i get a second hand or new auto window motor?
« Reply #10 on: 27 January 2004, 15:16 »
the passenger side switch glows i think cant realy check just now as im in aberdeen and the car is at home in dundee.
Offline Gambit
« Reply #11 on: 27 January 2004, 15:22 »
then next time your back at the car swap the switches round and see what happens
Offline Ciaran
« Reply #12 on: 27 January 2004, 15:35 »
will do do the just pull out and plug back in?
Offline lowgolf
« Reply #13 on: 27 January 2004, 15:39 »
Both my switches glow whatever, even when keys arent in and lights arent on. Is this normal or does it need to be rewired?
<br /><br />Yeah!!!
Offline Gambit
« Reply #14 on: 27 January 2004, 15:55 »
Ciaran, yes you just pull the switch & its housing out of the centre console, then just pull the two apart.
lowgolf, im not sure about the lights glowing when the keys arent in the ignition, ill have to check
Offline Ant
« Reply #15 on: 27 January 2004, 17:40 »
Lowgolf, the switches shouldn't glow with the keys out of the ignition, do glow when in (regardless of if lights are on), indicates a problem possibly at the ignition barrel, or maybe just wiried wrong.
Ciaran, if one light glows and the other doesn't probably a blown bulb in the one that doesn't when you switch them round you should be able to see for sure.
Fuses are inline thermal AFAIK.
Offline Ciaran
« Reply #16 on: 28 January 2004, 12:39 »
il have to try swapping the switches around and see!  ;)
