Author Topic: coolant thermostat  (Read 1431 times)
Offline yabbie
coolant thermostat
« on: 11 February 2007, 10:56 »
hi all i know this it a pig to do this thermostat but i have a little problem right so i took out the air box to give me some more room. took off the under plastic trim under the car engine took out the alternator. took off the timing belt cover the top half broke that whilst removing took off three bolts holding the water pump but i still cant get it off people say you have to take off the pulley but i cant every time i try to use an allen key in one of the bolts the pulley just spins i tried putting the belt together but it still spins please some one give me so info thanks
Offline EvilScotsman
Re: coolant thermostat
« Reply #1 on: 19 February 2007, 22:38 »
isnt the thermostat in the pipe elbow at the front of the block? I'll get the haynes outa the car boot tomorrow but i wouldnt think it would be inside the water pump....
"Handheld OBDII Scanner"
Offline yabbie
« Reply #2 on: 20 February 2007, 07:44 »
well that would be great if it was please tell me its not so that the whole day i wasted trying to get to the water pump wasnt for nothing lol
« Reply #3 on: 20 February 2007, 10:26 »
yeah to get to the thermostat you need to take the PAS pump off, not the waterpump ;)
Follow the bottom radiator hose, where it connects at the other end is the thermostat housing :)
Offline yabbie
« Reply #4 on: 20 February 2007, 18:49 »
 :sick: i spent all day taking all the bits out so let me get this straight follow the bottom hose away from the rad and look for where it connects but i thought it goes to the watter pump ? oh the pain i was right there i think i took off a little clip that was connected to the pipe think it was holding the pipe in place  :cry: :cry: :cry: :cry:
« Reply #5 on: 20 February 2007, 18:55 »
it goes to a plasic elbow on the bottom of the waterpump, which covers the thermostat.  To remove it you need to move the PAS pump out of the way :)
« Reply #6 on: 20 February 2007, 21:24 »
The PAS pump is easy to take off. 2 bolts off and swing it out but watch the pipe connections dont get strained. WHen refitting it - leave tightening the double bolt/gear-nut on the outside till you adjust the bigger "gear-nut" to the right belt tension then do them both up.
Follow the fat bottom hose as rubjohnny says and the wee cover its connected to holds the thermostat. The gasket will need replacing once you disturb it. You could use instant tho I wouldnt. a gasket is only a couple of quid :O)
Offline yabbie
« Reply #7 on: 21 February 2007, 19:41 »
sorted thanks heats up nicely now  :grin:
