Author Topic: Rear Wiper Woes  (Read 997 times)
Offline JMallows
Rear Wiper Woes
« on: 05 February 2007, 22:11 »
Right, i have a problem with the rear wiper. It started a little while ago, when i put it on, it wiped just under half the screen and stopped  :angry: Every time i did it, it would park in funny places, each time doing sort of half a wipe... My first thought was relay, its not supplying the power for long enough. Replaced, same problem.
Next, i took the linkage out, cleaned it up, and greased the spindle, common problem with rust i gather... Same problem.
Next, i tried a new motor, which worked perectly in the donor car, doing the whole wipe, put in mine, same half wipe problem!
Now i dont know where to go! I've done everything i can think of!
Help! Could it be the fusebox, as i have had a few probs with the fog light, whic i believe is the fusebix?
A clever person solves a problem. A wise person avoids it.
Offline Thom89
  • Looking for an "Icebreaker"
Re: Rear Wiper Woes
« Reply #1 on: 05 February 2007, 22:42 »
Could be a broken wire! top of the tailgate (lefthand side) where the wires come out of the body, and enter the tailgate, pull back the rubber sheathing :rolleyes: and have a look.. if you have broken wires, solder back together, and use heat shrink to finish the job off properly.. hope it helps
Tom
Offline DarnPB
  • Formerly Darnpistonbroke
Re: Rear Wiper Woes
« Reply #2 on: 06 February 2007, 06:59 »
I have the same problem and the first thing I´m going for is a bad earth check. :wink:
Offline Strev
Re: Rear Wiper Woes
« Reply #3 on: 06 February 2007, 09:04 »
Can you keep us posted - I have the same problem. Have replaced motor twice and relay. Problem remains. Drives me mad seeing the wiper half way accross the rear screen!
Offline Simpson
  • one day il learn
Re: Rear Wiper Woes
« Reply #4 on: 06 February 2007, 09:24 »
had the same problem, definitely a broken wire in tailgate.  :smiley:
i must buy a new car!
Offline JMallows
Re: Rear Wiper Woes
« Reply #5 on: 06 February 2007, 13:50 »
Yeah, i forgot to mention that i already had the problem with the broken wires, and i already fixed that problem :( So i'm still lost!
Also, surely if the wires were broken, it would be more intermittent, stopping at lots of different places...?
Offline Simpson
  • one day il learn
Re: Rear Wiper Woes
« Reply #6 on: 08 February 2007, 21:00 »
thats exactly what i thought i think another wire goes to the relay to give it extra power, check wiring again mate to be sure.  :smiley:
Offline JMallows
Re: Rear Wiper Woes
« Reply #7 on: 09 February 2007, 10:57 »
Yeah, i suppose it cant hurt to check after all!
Offline Gambit
Re: Rear Wiper Woes
« Reply #8 on: 09 February 2007, 13:41 »
mine wouldnt work at all. turned out to be the stalk itself
