Author Topic: how to build bandpass e...  (Read 4157 times)
Offline dubaudio1
« on: 23 January 2004, 22:55 »
hello
thanks all of you for replay on mi ice connection problem.it`sorted.now i`v got anather one.iv got new sub vibe blackair 10`.(i buy it on e-bay for 60 pounds for two,brand new,proper deal,thare are some more if you fancy) anyway i`m thinking of building a bandpass enlosure.can anyone give me some advice how todo it.whare to start and all that staff.i was thinking about taking all dimension from original vibe AC serie box,but i dont know whot is happend inside that box.please help.
Offline lowgolf
Re:how to build bandpass e...
« Reply #1 on: 24 January 2004, 18:41 »
there are different kinds of bandpass boxes as well. different orders.
The 4th order bandpass is basically a driver placed in a sealed box with an identically tuned port on the other side of the sealed section. So basily you have a sealed enclosure behind the cone and a ported enclosure infront of the cone
The 6th order bandpass system is similar to the 4th order bandpass system , except in this case both the front and the rear enclosures are ported.
The vibe ac series is 5th order, It uses two sealed enclosures behind the subs, and one enclosure in front that they share with 2 ports.
<br /><br />Yeah!!!
Offline lowgolf
« Reply #2 on: 25 January 2004, 10:37 »
Apparently both enclosures should be slightly smaller than if you where just making a normal one. But i dont know how "slightly" smaller this is sorry.
<br /><br />Yeah!!!
Offline lowgolf
« Reply #3 on: 25 January 2004, 10:41 »
The vibe blackair has Recommended Enclosure Volume: 1.25 Cu.Ft. Dont know if this helps
<br /><br />Yeah!!!
Offline dubaudio1
« Reply #4 on: 25 January 2004, 11:06 »
thanks,i`m confiuse becouse if you look both vibe boxes cbr100 and ac100 theye ara nearly the same whare ac100 is split at list at haff so the magnet will have about haff less space then supoustu have(1.25cbf).i dont know is well.thanks anyway i gess i`l have to try and have a look how it sounds.
sorry for my speling i`m not english.
