Author Topic: Clutch grinding noise  (Read 3861 times)
Offline caddyrage
« on: 05 February 2007, 00:16 »
Well the 2L pb digi is up and running fine now after some timing troubles :rolleyes:. But as 1 problem is solved, another arises :angry:.
When i did the conversion in my caddy, i fitted a new clutch and used a 5 speed diesel gearbox. I press down on the clutch pedal to here a grinding type of noise. Has anyone came accross this prob before?
I'am positive that i fitted everything correctly so its left me scratching my head plus i'am gutted i cant go for a spin just yet.
Please could someone shed some light on the matter.
 :smiley:
03 ibiza PD 130 sport, smiles per miles!
83 mk1 golf gti, 16v 2L PL
92 mk1 caddy, now stripped for resto
WWW.FENDUBBERS.CO.UK
cambridgeshire vw owners club
Re: Clutch grinding noise
« Reply #1 on: 05 February 2007, 11:27 »
sounds like it could be the release bearing, does the car actually move?
Edit: What clutch kit did you buy for it?
Offline Golf8vGti
« Reply #2 on: 05 February 2007, 12:44 »
This sounds familir to when we used a 2litre clutch on a 1.6 box and the splines hole was to big so it just spun freely causing a grinding noise. Sure you got the correct clutch??
Offline caddyrage
« Reply #3 on: 05 February 2007, 12:48 »
I used a valeo 200mm clutch mated to a mk3 gti flywheel. The flywheel happens to be the same as the old 1.6 carb engine i took out.
« Reply #4 on: 05 February 2007, 13:01 »
Hmm, the clutch should be a 210mm one ideally, I don't think 200 would be man enough?  In fact, I don't think there is a 200mm fitment MK2 clutch?
Edit: Ah its a diesel clutch!  In that case it should be fine, perhaps you've fitted it on the wrong way round?  Can you select gears with the engine on and drive the car?
« Last Edit: 05 February 2007, 13:03 by rubjonny »
Offline caddyrage
« Reply #5 on: 05 February 2007, 13:14 »
Prob is 210mm as it fit nice in the mk3 gti flywheel. I've fitted it the right way. I can select all gears now with engine off but dont fancy trying it with engine on due to the clutch noise.
« Reply #6 on: 05 February 2007, 14:33 »
any idea what model clutch it was specifically, as said if its a MK3 gti 8v or MK2 16v clutch it wont work with the gearbox you're using.
Offline caddyrage
« Reply #7 on: 05 February 2007, 15:47 »
It was for mk3 gti 2L 8v and a seat model, prob ibiza. Whats the difference then? Would fitting a mk3 gti box help?
« Reply #8 on: 05 February 2007, 15:53 »
aha theres the issue, the splined hole in the middle of the 8v clutch disc is too big for the gearbox, you need to either fit a MK2 8v GTI friction disc, or a MK3 2.0 8v or MK2 16v gearbox :)
Offline caddyrage
« Reply #9 on: 05 February 2007, 16:00 »
Oh S**t  :sad:. Gotta have the box off again!. Well atleast i know what the prob is now, Cheers mate :smiley:
