Golf mk3
hardmonkeys
Coolant thermostat
Topic: Coolant thermostat (Read 1182 times)
yabbie
GTI forum regular
Coolant thermostat
03 February 2007, 09:55 »
can anyone confirm if the coolant thermostat is under the water pump is it a right pig to get at
robster23
Now a VW Fox Owner.
Re: Coolant thermostat
03 February 2007, 18:44 »
I'm told that yes that is where it is and Yes it IS a pig.
Why are you considering changing it? I ask because my temp water temp gauge is always very low and I thought that may help?
It's urban right? That means it must be tougher, obviously.... ;-)
boneybradley
Forum Supporter
Serious forum addict
Back in a Mk3...
03 February 2007, 18:53 »
On the 2.0 it is next door to the water pump in a housing.......
1 remove the pas belt for access
2 remove the pas pump mount (don't undo any haoses)
3 remove hose from coolant pump housing
4 remove 2 bolts from thermostat housing and remove housing
5 take stat out (make sure you use a new rubber ring gasket)
fitting is a reversal off removing..oh and also empty the coolant before anything alse as there's a fair bit of water there
and robster does your car get warm (i.e heater) as this could be the temp sensor at fault
yabbie
GTI forum regular
03 February 2007, 19:54 »
i want to change it cause it takes a good 15 mins to warm up and i think it get stuck open and closed on diffrent occasions so its still a real pig of a job to do then
robster23
Now a VW Fox Owner.
03 February 2007, 20:13 »
Hey Boney,
No, the gauge shows in the coldest 3 bars at all times unless i'm stationary for a period of time then it goes to half way. I should have thought it should sit just below half way all the time?
Thanks Mate,
Rob
boneybradley
Forum Supporter
Back in a Mk3...
03 February 2007, 20:29 »
robster i had a similar problem with my old golf...and that turned out to be the temp sensor.....
If she is blowing hot air from your heater when it show's cold I would try that first
robster23
Now a VW Fox Owner.
Reply #6 on:
03 February 2007, 20:57 »
Ok mate thanks. The MFA shows an appropriate oil temp while the coolant gauge is set at cold so i'll give it a look. Looks like ECP will be getting lots of my money this month!
Golf mk3
hardmonkeys
Coolant thermostat
