Author Topic: central locking - not worked since battery removal  (Read 745 times)
Offline JULEE
« on: 01 February 2007, 21:18 »
Hi
since I've had the battery out of my car to perform some work, my central locking will not work.
Is there some sequence to re-connecting the battery which will make it work again?
The pump works as I have had power to it and it runs.
Thanks
Julee
 :cry:
Offline robster23
  • Now a VW Fox Owner.
Re: central locking - not worked since battery removal
« Reply #1 on: 01 February 2007, 22:08 »
That sounds like a fuse or a relay that has gone pop as the battery was disconnected / reconnected. Sometimes a short / surge can occur. Check those if you haven't already.
I can't imagine that there is an order to putting the components back in the circuit to make them work.
HTH
It's urban right? That means it must be tougher, obviously.... ;-)
