Author Topic: Throttle body question  (Read 1216 times)
Offline gti_mk3
« on: 31 January 2007, 22:12 »
Hi
Does anyone know how long it takes to remove the throttle body on a Mk3 8v to clean it properly? I've sprayed a can of carb cleaner thru it and its a lot better but really needs taking off I reckon. any advice  /tips /pitfalls? Is it do-able on a saturday afternoon?
Chris
Offline yabbie
Re: Throttle body question
« Reply #1 on: 31 January 2007, 22:23 »
done mine on a 16v 2.0 abf took me half hour cleaned bolted back on no more over revving for me
Offline kr1s77
« Reply #2 on: 31 January 2007, 22:49 »
do you have to disconnect the black plug and re-programme it or does it do that itself. what do you use to clean it? do you use a new gasket, if there is one. because mine over revs/ sticks when it is warm so might do this on the weekend.
thanks
ASV 1.9 TDI 110
Offline GuvGTI
« Reply #3 on: 01 February 2007, 22:47 »
Have a read with thanks to blackmk3  :smiley:
http://www.golfgtiforum.co.uk/index.php?topic=51901.0
Offline robster23
  • Now a VW Fox Owner.
« Reply #4 on: 01 February 2007, 23:55 »
It's a good write up!
Where can you get the gaskets without upsetting your local VW dealer with such a small order - I can't stand going in if I only need one thing, the "You are wasting my time look" just ruins my day!
Rob
It's urban right? That means it must be tougher, obviously.... ;-)
Offline yabbie
« Reply #5 on: 02 February 2007, 18:18 »
euro car parts
Offline robster23
« Reply #6 on: 02 February 2007, 19:43 »
Any idea on the part number / name? Can't seem to fine Throttle Body Gasket!  :undecided:
