Golf mk2
Handbrake Lever
Topic: Handbrake Lever (Read 852 times)
Haribo!
Handbrake Lever
31 January 2007, 19:36 »
ive had all my pads changed and now my handbrake pulls up alot higher, it pulls up quite away before i feel any tension, how do i go about tightening it?
Ktuludays
GTI forum regular
Re: Handbrake Lever
31 January 2007, 19:42 »
take the handbrake lever trim off - 1 screw at the back.
slide this off.
you will see where the handbrake cables come in from the underside of the car and are held by some nuts to the lever. tighten the nuts up. this should do the trick.
may need to play around with them a bit to get the right tension.
if the cables are at maximum adjustment then you will need new ones. they are about £12 each from vw.
<br /><br />What don\'t kill ya, makes you more strong!
Haribo!
Re: Handbrake Lever
01 February 2007, 18:50 »
sorted cheers
Golf mk2
Handbrake Lever
