Golf mk3
hardmonkeys
relays
Topic: relays (Read 1971 times)
swalk999
relays
31 January 2007, 14:18 »
sorry I have been reading loads of topics about replacing the ECU RELAY no 30
FUEL PUMP RELAY 167
SORRY FOR BEING STUPID BUT WHERE CAN I FIND THESE NOT HAD THE CAR LONG AND NOW RUNNING CRAP
STEVE
Len
10k hero
Re: relays
31 January 2007, 14:32 »
Under the dash to the right of the steering wheel is the fuse box. The relays are in there above the fuses.
Bit difficult to see, you need to kneel down outside the open drivers door and peer up in and under.
www.sas.org.uk
www.the-ace.org.uk
patch900
Here all the time
Re: relays
01 February 2007, 16:32 »
Somewhere on here, I think its rubjonny or boneybradley has posted a scan of the layout of all the relays so you can see what is what.
Its in relation to stuff like this, you can always check their posts.
Its definately on around here somewhere
Virtually everything I know about the workings of the internal combustion engine can be written on the back of a small stamp with a large marker
monkeyalan
Re: relays
01 February 2007, 16:37 »
there are about a million posts relating to this subject
It seems to be the first thing newbies want to know about.
EvilScotsman
GTI forum regular
Re: relays
05 February 2007, 22:22 »
hi mate,
Top row 3rd from left is the ECU relay marked 30 and bottom right is Fuel Pump Relay marked 167.
Ecu is relay position 3 and fuel position 15.
whit
GTI forum regular
Re: relays
08 February 2008, 18:48 »
is it easy to see if a relay is faulty by looking at it? or can you test it?
i know i read before about cracks in the solder joints but can these be easily seen?
i've removed the plastic covers from my ECU and fuel pump relays and they look ok but i'm not really sure what i'm looking for?
boneybradley
Forum Supporter
Serious forum addict
Back in a Mk3...
Re: relays
Reply #6 on:
08 February 2008, 19:30 »
heres the thread that will help you locate it
http://www.golfgtiforum.co.uk/index.php?topic=74087.0
and i dont think you can really test them..only try them in another car and if the fault occurs on that car you know its knackered
Len
10k hero
Re: relays
Reply #7 on:
08 February 2008, 20:44 »
Its dead easy to test em guys!
Warm up the car, a good blast the stop.turn off and pull it out. If its warm to the touch then its OK but if cold then its duff!
Simple.
www.sas.org.uk
www.the-ace.org.uk
MrTurner
Facelift leon cupra
Re: relays
Reply #8 on:
15 September 2008, 15:22 »
^^ Does this actually work? Get the car to temp, pull the relay and if warm it works? Would save spending cash unless it really is needed!
VW BUSH
Guest
Re: relays
Reply #9 on:
15 September 2008, 19:26 »
you can test em with a meter and a car battery but to be honest it aint worth it as most tend to have intermittent faults, as they warm up the contact is broken etc
I would just buy a couple of each and keep em safe for later! They dont seem to last long ive had three n0 30s, one a year on my old girl. i think the Poo colour signifies the quality
Golf mk3
hardmonkeys
relays
