Author Topic: relays  (Read 1194 times)
Offline swalk999
relays
« on: 31 January 2007, 14:16 »
sorry I have been reading loads of topics about replacing the ECU RELAY no 30
        FUEL PUMP RELAY 167
SORRY FOR BEING STUPID BUT WHERE CAN I FIND THESE NOT HAD THE CAR LONG AND NOW RUNNING CRAP
STEVE
Offline garfayliu
Re: relays
« Reply #1 on: 31 January 2007, 15:44 »
hey Steve,
You'll find the relay's above the fuse box on the mk3 golf. you'll find this under the dash/steering wheel on the driver side. If you look under neath there'll be a panel with two green plastic buttons which you push in to release the panel, before you yank it out.
A torch will help, but you'll see a row of fuses then several plastic cubes/squares, about 2cm wide. You should then see the numbers 30 and 167 printed on them
HTH, Garfay.
Offline patch900
Re: relays
« Reply #2 on: 02 February 2007, 12:47 »
Hi, there is a post about this - I think it was boneybradley, len405 or rubjonny.
They put a scanned pic of the relay layout on the site, someone must have sticked it.
Virtually everything I know about the workings of the internal combustion engine can be written on the back of a small stamp with a large marker
Offline Len
Re: relays
« Reply #3 on: 02 February 2007, 12:52 »
Wasnt me!
I just tell how to test em!
www.sas.org.uk
www.the-ace.org.uk
Offline patch900
Re: relays
« Reply #4 on: 02 February 2007, 12:54 »
Bradley or jonny then, although Len knows lots  :wink:
Offline Len
Re: relays
« Reply #5 on: 02 February 2007, 13:01 »
I'm just too lazy to post pics thats all.  :grin:
Also its my pet subject as its the reason I joined this forum to resolve a problem and got told straight away it was the relays!
« Last Edit: 02 February 2007, 13:04 by Len405 »
www.sas.org.uk
www.the-ace.org.uk
Offline boneybradley
  • Back in a Mk3...
Re: relays
« Reply #6 on: 03 February 2007, 17:29 »
Here you go....
